706-C Forklift Engine Manufacturer
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Topic: 706-C Forklift Engine Manufacturer
    Posted: 26 Aug 2024 at 8:58pm
I'm looking for a governor for the gas engine in my forklift, but do not know who manufactured the engine?
Understand it could be ford or continental or ????
is anyone familiar with these machines?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2024 at 4:37am
Swinford's book says Perkins 4.203, gas or diesel Perkins 4.236 in the 706 C...Wink
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2024 at 7:47am
So its a Perkins 4.203 gas engine, then??
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2024 at 8:52am
Morning Amos: Perkins usually had a flat casting block machined into the side of the engine with the identifying numbers of the engine machined into the surface.  At least that was the case for the 4-236 in the 715 and 715B series backhoes.   The 706 AC Forklift shares some similar components (driveline) to the AC 700 series backhoes so therefore similar.
That said, I would recommend you take a small wire brush and get after the block and hunt around for a Perkins tag or see if you can find the casting it may be buried under grease and oil build-up.  HTH's ~ Orangeman
Edited by orangeman - 27 Aug 2024 at 8:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2024 at 3:56pm
https://www.allischalmers.com/forum/706-b_topic41297.html
DIESEL was Perkins ........ GAS ...( Perkins G4-203 or G4-236 ) ... older had FORD
Perkins only made a few variations of GAS engines.. most were diesel ... Sticker or TAG somewhere ?
Edited by steve(ill) - 27 Aug 2024 at 4:07pm
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2024 at 6:25pm
mine has the g4-203
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2024 at 2:35pm
What’s the top of your 706c’s engine look like?
Does it have an overhead valve train with a tin valve cover(ford/Perkins)?
Does it have a flat-top cast head with distributor sticking up in center of it(Continental)?
My 706b has a transplant flat-head continental in it. Some previous owner probably replaced original Ford engine with it? Continentals are plentiful in the forklift world.
Edited by AC7060IL - 30 Aug 2024 at 2:42pm
This page was generated in 0.205 seconds.
