Power shift for pulling?
Mattman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mattman Quote  Post ReplyReply Direct Link To This Post Topic: Power shift for pulling?
    Posted: 26 Aug 2024 at 6:50am
I have a power director 7040 and love it. I'm looking at a power shift 7040 tractor to make into a puller. Is this a mistake? Should I be looking for a power director to pull with? By the way, I cant pull with my current 7040 as it is a low hour family heirloom. Thanks everyone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2024 at 7:21am
HOW MANY HP ARE YOU INTENDING TO RUN ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mattman Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2024 at 7:56am
No more than 220 horses
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2024 at 8:34am
Power Shift is fine, but less speed choices.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2024 at 2:30pm
Many have pulled with Power-Shift-Transmissions. I've even done it myself. However once you get into it are you absolutely sure you will never decide to go faster with more HP? With that in mind I'd be looking for a gear drive instead of a Power-Shift. With my hands on experience in high HP pullers NEVER downshift with a Power-Shift. Find out what gear you can handle and never go any higher than that.
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2024 at 2:52pm
Why don't you downshift?
Edited by bigal121892 - 26 Aug 2024 at 2:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2024 at 3:00pm
Well in my past experience with a Power Director- some shifts can be smooth some not- you.ve got tons of weight behind you- then changing the inertia of everything - can work out but sends shock thru the drivetrain,, Powershifts have to be tight ; just my opinion now
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2024 at 3:50pm
Things don't happen when upshifting, however from PRESONAL experience with HIGH HP pulling, downshifting is when things break.
Edited by PaulB - 26 Aug 2024 at 6:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2024 at 6:42pm
Things don't happen when upshifting, however from PRESONAL experience with HIGH HP pulling, downshifting is when thigs break.
Thanks for the reply. I have never pulled, and assumed it was something like that, but you know what assuming gets you. :)
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2024 at 7:30pm
the downshift isn't quick enough for sled pulling, my 7040 PD that I pull on occasion is fine to shift up at start of pull, but have tried downshift at end and it stops, then takes off again, very abrupt, so I just quit using it to downshift. I think mods have been done to them to make them shift quicker, but mine is all original in the PD section.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2024 at 7:46pm
The speed with which the clutch packs release and engage has to be quickened up as the HP increases. 220 HP isn't an issue but 400 HP sure would be.
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2024 at 7:33am
A cousin of mine was at a tractor pull in the '70s after Allis came out with a power shift transmission.  There was one pulling and he up shifted and down shifted.  The announcer made the comment " That tractors got more gears than Carters got liver pills!"  I dont know what year or how the tractor did, but thought it was a funny story.
Life is simpler when you plow around the stump.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2024 at 8:32am
https://youtu.be/8KwziQ7czFg?si=DUKz-5w7OGon6DPh
  The first 8050 is PS, about 350 HP.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2024 at 7:02pm
That was a wonderfully hook !!! Did you raise the power shift regulating pressure any  ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2024 at 7:25am
The Allis 12-speed Power Shift should look pretty good in classes where your top speed will never be above 6MPH. When in LOW range your speeds are 1 MPH apart from 5th on down and are pretty nice clean/smooth shifts. Where the Allis tranny wouldn't look good is where you are expecting ground speeds of over 6 MPH as the spread between gear selections becomes quite wide.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2024 at 7:54am
Is that you pulling Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2024 at 8:07am
  No, just the torque limiter was beefed up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2024 at 8:09am
  Nope, brother always pulls that one, wife is in second one though.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2024 at 6:39pm
Congratulations to your brother & wife ~ they both had great pulls. The Power-Shift was a very smooth pull !! I felt like he was never going to stop? Thanks for sharing the video.
