What is size of core plug in head of wd
kevin LA-CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevin LA-CA Quote  Post ReplyReply Direct Link To This Post Topic: What is size of core plug in head of wd
    Posted: 24 Aug 2024 at 5:00pm
Core plugs in the WD head are rusted through.
If the are the same as a B - they are 1.250". Not near the tractor now, so appreciate the help.
Tall head if this makes a difference.
Kevin
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2024 at 6:01pm
Per Allis Parts Catalog: WD and WD-45 P/N is 203093.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2024 at 6:47pm
  • Compatible with Massey Ferguson Tractor(s) 243, 250, 261, 399, 4220, 430, 451, 471, 481, 491, 492, 583, 596, 650, 680, 2625, 4215, 4225, 4233, 4235, 4240, 4243, 4245, 4253, 4255, 4260, 4263, 4265, 4270, 4315, 4320, 4325, 4345, 4355, 4360, 4365, 4370, 5275, 5285, 5290, 5300, 5320, 5425, 5435, 5445, 5450, 5455, 5460, 5465, 5475, 6235, 6245, 6255, 6260, 6265, 6270, 6280, 6290, 6445, 6455, 6460, 6465, 6470, 6475, 6480, 7465, 7475, 8120, 8210, 8220
  • Compatible with Perkins Engine(s) A3.152, A4.236, A4.248, T3.152.4
  • Replaces Massey Ferguson OEM Number(s) 731354M1, 735865M1, 731354V1
  • Replaces Perkins OEM Number(s) 0650710, 0650563
  • Replaces Allis Chalmers OEM Number(s) 70203093
  • Replaces Ford OEM Number(s) 115411EA
  • Replaces JCB OEM Number(s) 02100396, 02100105
  • Diameter: 1.25"
  • Style: Cup Type
191574 | Freeze Plug | Massey Ferguson 243 250 261 399 430 451 471 481 491 492 583 596 650 680 2625 4215 4220 4225 4233 4235 4240 4243 4245 4253 4255 4260 |  | 70203093 | 115411EA | 02100396 | 731354M1 | 0650710 | 02100105 | 735865M1 | 731354V1 | 0650563
Edited by steve(ill) - 24 Aug 2024 at 6:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2024 at 10:42pm
Must be the same....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 6:19am
There still available from agco.
Edited by Mikez - 25 Aug 2024 at 6:24am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 6:23am
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevin LA-CA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 8:24am
Thanks for the input. Not near an Agco dealer - even though I live 8 miles from the Oxnard plant.
I bought dorman 555-023 for my B, appears to be the same for the WD. Picked up a pair from napa. Should work.
Pfouts Family Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pfouts Family Farm Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 9:08am
I know the B and the WC are the same.  WD I would assume to be the same as a WC, so I think you should be good with what you picked up.
