Latex paint-long term storage………….
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: Latex paint-long term storage………….
    Posted: 21 Aug 2024 at 1:21pm
Is there a limit on maximum temperature for storage of latex paint? We know not to allow latex to freeze, as it turns lumpy. But, does the same happen if temperatures are too high? Are certain brands more tolerable to storage in hot temperatures?
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2024 at 3:07pm
Timely post. I just opened a year old almost full gallon of paint and it looks about to go bad. It's in my climate controlled shop too. I have very little luck saving paint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2024 at 5:31pm
hmm...
maybe carefully add water  above the paint ?
also put into smaller can so less air in the can.
Google probably has a few ideas.....
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2024 at 5:45am
I have heard that you should make sure the lid is on tight and store the container upside down to seal it up.
GSTROM99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GSTROM99 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2024 at 9:19am
The new style "screw on top" plastic gallon jugs that I have been buying seem to seal and store pretty well.  I keep mine in my basement, so heat isn't an issue.  HOT storage will be bad for anything (esp paint)...
Edited by GSTROM99 - 24 Aug 2024 at 9:21am
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2024 at 9:30am
got 3 --- 5 gallon buckets here in the basement,-- never opened and been there for 10 years or more. I turn them upside down ever once in a while. Dont have time to use it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2024 at 10:08am
There is a Lifespan on Latex Paints, much as anything Organically Based, started rotting the day harvested, continues to rot until that little spot swells into the entire can/bucket.  Spoke to our local Hardware store, Base Latex Paint if does Not sell within two years goes Back to the producer for destruction as will fail to perform adequately for the protection they claim and present.
Edited by DMiller - 24 Aug 2024 at 10:08am
This page was generated in 0.348 seconds.
