7060 open station |
Mattman
Joined: 20 Dec 2012 Location: Plover, WI Points: 231 |
Topic: 7060 open stationPosted: 20 Aug 2024 at 5:01am |
Anyone have any advice on converting a 7060 into an open station tractor?
coggonobrien
Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1864 |
Posted: 20 Aug 2024 at 11:43am |
Fenders will be the hard part, everything else is available new. I wouldn't mind building a stamp to convert 200 fenders to single head lamp.
Cpetty
Posted: 20 Aug 2024 at 12:20pm |
Yeah, that's a big job! You'll need to fab a new ROPS and figure out how to reroute all the wiring and hydraulics.
Michael V (NM)
Posted: 20 Aug 2024 at 9:51pm |
Fix the A-C...
Mattman
Posted: 21 Aug 2024 at 6:52am |
Im going to pull with this tractor and want to get rid of that weight.
Mattman
Posted: 21 Aug 2024 at 6:53am |
I'm curious as to what guys have done for the floor plate I guess.
DrAllis
Posted: 21 Aug 2024 at 7:31am |
I take it you've never pulled before ??? A 7060 shipping weight is just over 12K. I had a 7050 once that we removed both cab doors and windows, one battery instead of four, removed the 3-point hitch draft arms and links and were under 12K with cast iron rear wheel centers, which could lose you another 500-700 lbs if you went to pressed steel.
Mattman
Posted: 21 Aug 2024 at 9:45am |
I have pulled. Goal is to get to 9750.
DrAllis
Posted: 21 Aug 2024 at 1:24pm |
Earlier post was to get it under 13,000 lbs.
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5124 |
Posted: 21 Aug 2024 at 1:38pm |
I'm not sure that is even achievable without major reconstruction.
Mattman
Posted: 21 Aug 2024 at 2:55pm |
Yup, I wrote 13,000 on earlier post. My mistake. I really want to get it under 10. I will remove pto, hydraulics, 3 point, pressed wheels, cab. I'm thinking aluminum floor plate painted maroon. May have to modify front axle to make it lighter. I know another guy who did the same thing. Following his lead.
DrAllis
Posted: 21 Aug 2024 at 4:40pm |
Brad Howells 7030/8030 NTPA four turbocharged unit pulled at 9500 with 30.5 x 32's and I know he added weight to get up to 9500 lbs so it would balance.
