Let’s Get Her Started!
Derricks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Derricks Quote  Post ReplyReply Direct Link To This Post Topic: Let’s Get Her Started!
    Posted: 18 Aug 2024 at 12:43pm
Allis Chalmers D17 Series IV
Fluids look perfect.
Put in new fuel.
Put in new spark plugs.
It turns over very well but doesn’t fire.
Next step carburetor?
Edited by Derricks - 18 Aug 2024 at 12:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 1:15pm
Check spark. Pull coil wire from cap and hold end 1/4 inch from block while cranking. Should jump a blue flame. If no spark won't matter what you do to carb.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 2:30pm
Fuel+air, intake... compression, ignition, fire... timing.
If you have all these, and it still won't start, it's because you don't have all those...
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 5:03pm
Are you sure you don't have spark? Sometimes it's hard to see. Try it after dark to see for sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2024 at 9:51pm
....he says it doesn't "fire". That doesn't mean it don't have spark. He needs to prove it does first.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2024 at 2:45am
Air, Fuel, Compression and Sparks are required to run.
  1. CHECK FOR SPARK AT COIL WIRE; pull wire from dist cap center, hold 3/16" - 1/4" from ground (cylinder head is good ground) and run starter.
  2. Check for sparks on at least 2 plug wires; hold 1 at a time same distance from ground and run starter.
  3. Remove plug in bottom of carburetor; does clean gas run out.? It should, old dirty gas won't run well. Reinstall plug.
  If these 3 check out, remove air inlet hose from carburetor inlet, set throttle 1/2 or full and pull choke out, crank engine 15 seconds, does it attempt to fire.?
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2024 at 6:13am
Probably file the points
snowman(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowman(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2024 at 4:24pm
I didn't see anyone mention the condenser as a possible culprit.
1950 WD, 1966 D-10 III, 1961 D-10 II, 1966 D-15 II Gas, A-C Minibike, 917 Hydro Mower, 917 Hydro Blower w/cab, West Michigan "Allis Express"
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2024 at 8:05pm
Any luck getting it to fire?
Assuming you’ve poured/sprayed gas into carb while engine rolls over?
If gas put into carb & still No fire, then could be many things? Mouse chewed wires? Aged brittleness wires? Bad electrical contacts, components~ coil? Points, distributor cap, ignition switch????
Verify that coil has electricity. If no electricity with ignition switched on, then run a hot wire from battery to coil and roll engine over by starter.
This page was generated in 0.044 seconds.
