H3 track width
PAhillbilly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PAhillbilly Quote  Post ReplyReply Direct Link To This Post Topic: H3 track width
    Posted: 16 Aug 2024 at 10:51am
Hello Evreyone, does anyone know if there are are different version of the undercarriage/tracks on H3s? Example wide track? And if so are the other undercarriage parts inchangeable?
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2024 at 11:36am
I believe the grousers are an inch or two wider on the blade version of the H3. Same track chains and sprockets though. No 'wide track version' in terms of the main body of the machine ever existed that I'm aware of. What some guys would do on Caterpillar bulldozers, is finding wider grousers and cutting off enough from the inner side of the pads to clear the frame and gear housings. On softer ground it would give a better chance to do your job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PAhillbilly Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2024 at 11:58am
Thanks. I appreciate the info
This page was generated in 0.031 seconds.
