AC C steam/smoke from bell housing
AllisChalmersCMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmersCMan Quote  Post ReplyReply Direct Link To This Post Topic: AC C steam/smoke from bell housing
    Posted: 15 Aug 2024 at 7:58am
My C has started to put out what looks like steam or smoke from the right side of bell housing under load, and occasionally when not under load. There's no water in the oil, and it loses only a little coolant from time to time. She loses oil but that's from the rear main. Last, she doesn't have quite the power she used to but I only notice because I have a steep hill I mow and she used to just barely make it to the top in 2nd and now she can't quite make it, close but not quite. She doesn't smoke from the exhaust.
Edited by AllisChalmersCMan - 15 Aug 2024 at 7:59am
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2024 at 9:16am
Maybe engine oil from the rear main seal leak is making it's way to the clutch plate?
This could cause clutch slippage and the resulting smoke.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2024 at 2:24pm
Can't make it to the top of the hill ??? Like it quits moving while the engine is still revved up ????????????    or it stalls/kills the engine?????
DanielW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielW Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2024 at 2:48pm
When you lose power, is the engine bogging down, or is it rather that the engine is up to speed and the ground speed and pto slow down? I would guess at a slipping clutch. Either worn out/out of adjustment and the smoke is the lining burning off while it slips, or else the oil out of the rear main seal has found its way onto the clutch lining and is burning off as it slips. Either would cause you to lose power/traction on a hill. Is there a strong smell associated with the smoke?
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2024 at 9:49am
sounds like clutch soaked with oil
