drilling tip
Post Options Post Options   Thanks (1) Thanks(1)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Topic: drilling tip
    Posted: 14 Aug 2024 at 10:50pm
Many of you likely know this already but drilling through stainless can be a chore. Years ago the guy at the welding shop told me to use castor oil. I tried it and was pleasantly surprised. Tonight I had to drill some 5/16 holes in a plate of 3/16 SS. Put a drop of castor at each spot and again surprised how well it works. For someone who doesn't know this,this could be a great tip.
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2024 at 8:36am
 HHHMMmmmmm,,,,Castor oil,,,huh,,?? That right there is something great to know,,!! Many Thanks SteveM,,,I'm now wondering if it will work on bed rails as them things are super hard for obvious reasons. I'm gonna check if you can get a small bottle to give it a try.Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2024 at 8:47am
machinest I knew, used to regrind drills 'angles' for SS use, also had a special set for polycarb(aka Lexan ).
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2024 at 10:14am
 Well, Jay,,,that right there is very interesting,,,you don't remember what that "angle" was,,,?? I would very much like to try that angle on ,,,,bed rails,,,????Clap
Post Options Post Options   Thanks (1) Thanks(1)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2024 at 2:59pm
Thanks for the advice. I always thought castor oil was for something else. 😁
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2024 at 7:59pm
Would cutting oil work?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2024 at 8:01pm
ANY oil is better than no oil !
I've got 3-4 cases of 10W40 here I use.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2024 at 9:01pm
 I had NO idea what Castor oil was used for but the thought of it being good for drilling SS,,and maybe even on them bed rails that I use a number of them,,,,,
 My curiosity finally got the best of me when I had to go to Walmart this morning and remembered about that dang Castor oil,,,,,,wrong, wrong,,,wrong!!they only had one good sized bottle and it was marked $28.66,,,,what in the heck is in that bottle ,,,,? Must be gold shavings,,,chit my curiosity left me in a heartbeat,,,,,LOLLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2024 at 9:24pm
 "SOME" bed rails are HARD... dont know why , but they got little chips of SOMETHING in them.. like carbide !! ..
Had an old machinst at work and i needed a 1/4 inch hole in something that was IMPOSSIBLE to drill... He worked over a carbide concrete drill bit... and put a cutting edge on it like a steel drill bit... SLOW and LOTS OF OIL and it  did the job... I was impressed !!
Edited by steve(ill) - 17 Aug 2024 at 9:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2024 at 9:51pm
Well, Hubert,,,what "WAS" or "IS"  it used for,,,? Man, that right there is some expensive Chit,,,, $28 for a small bottle,,,?WinkWink
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2024 at 10:10pm
 Hey Steve,,I have one of those hand held  Concrete Hammer drills that one of the carpenters gave me years ago. The tip is four point like a Philips screw driver and remember that he told me not to sharpen it as it would ruin the metal,,,??? You would hold the shaft and  strike the drill and rotate the drill 1/4" every time you hit the drill. Its amazing how  quickly you could drill a  1" hole in any concrete.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2024 at 10:20pm
srainless is realley very soft but heats and or workhardens very quickly , then it is hard to work with  must saw and drill slow and keep cool and lubed and its not bad to work with  and by al means dont center punch and harden were you have to start drilling  just start your holes with a center drill
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 2:58pm
In the early days of aviation, castor oil was used as engine lube because it didn't thicken up excessively in the cold temps at high altitude. Many of those engines were rotary types that used a total loss oil system; the oil fumes blew out all around the airplane and the pilots had to breathe the fumes, often resulting in them feeling compelled to relieve themselves immediately upon landing. Oh, the good ol' days!
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 3:38pm
When I was young about 65, 70 years ago, when I would watch the midget races you could smell the cars that used castor oil.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 5:38pm
Joe, it was used to “lubricate” your “plumbing” when you were a little bit “plugged up” and you had best not get too far from the pot. What section in Wally World did you find it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 6:12pm
https://www.facebook.com/reel/668025000862887
A real good video on quality and drill performance over several brands and within brands themselves -  Seems just about every bit is now made in China - except 1 IS , and one German drill company .
 From 0 holes in mild steel for one brand to over 480 holes - using same bit with another
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 7:14pm
The whole caster oil thing reminds me of a bit of useless knowledge tucked away in a corner of my brain...  If you really want to roll coal and all's you have is a gasser, drill a hole into the ex manifold, and rig a bulb to squeeze a load of castor oil into that hot manifold, and hit the gas, clouds of black smoke will emanate from your tail pipe.  I wouldn't try this on a car with a cat converter...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 8:07pm
 Well Chit, Hubert,,,I had no idea,,,!!!LOL Now I know,,,Wink
 Actually as I walked into Walmart,, I whipped out my trusty IPhone and called up the Walmart App to see where the castor oil might be and long about then,,I knew I was not gonna buy any of that high priced "stopper plugger upper" especially at the  $28  price.,,!!  the app said it is at the Pharmacy area,,,,
 I keep a bottle of Tap Magic at my lathe and one at the big drill press. The Tap Magic is made especially for machining and drilling and costs less than half of that dang castor oil,,,,,Big smile
Clay View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 9:58pm
We use caster oil for belt dressing on our J.I. Case 140W square hay baler.  Just a very very small amount on the flat belt will improve the grip and hold to the center of the pulleys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2024 at 2:38pm
Remember back in youth when I had a 35 Ford 5 window coup stock car , every so often at a race you could smell burnt castor oil in the air as some would add it to their fuel - said gave better performance - but supplemented Aviation fuel of high octane which had no lube in it .
 Remember the smell well as those dirt tracks back then were bowl shaped depressions , with fans setting on hill around them .
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2024 at 5:00pm
I think some would add nitro in the mix also.
When I made model airplane fuel I would mix methanol, castor oil and nitro methane.
Edited by nella(Pa) - 19 Aug 2024 at 5:24pm
