synthetic gear lube
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Topic: synthetic gear lube
    Posted: 02 Nov 2010 at 9:00pm
can any of you gurus tell me if i use synthetic gear lube (80-90 wt) will itaffect the seals that have been in these older tractors in the transmissioin and differential???
bwp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bwp Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2010 at 10:49pm
jw,
I have never used synthetic oil in a tractor, but I have tried full synthetic 15w in my plymouth roadrunner. I did not have any problems with it leaking past the main seals, however the engine did burn off a significant amount of oil compared to regular 15w oil. For whatever reason the synthetic oil slipped past the piston rings in much greater quantity compared to regular 15w. I have read that since synthetic oils are artificially created and the oil molecules are all uniformly smaller, synthetic oil slips past the larger bearing and ring tolerances in older engines. I have also read that synthetics have a large amount of cleaning detergents that can swell gaskets and seals in older engines that are not designed for synthetics. I would stick with regular gear oil, certainly cheaper. Just from my experience, hope this helps you.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2010 at 7:17am
My experience with synthetic oils is this.  If you have a leak before, it will leak after.  If you don't have any leaks before then you won't have any after.  I run it in everything and I mean everything from tillers to tractors to trucks.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2010 at 9:26am
Synthetic oils never have had a problems with seal in any application.  What was the problem, when they first came out, there was some very bad oils out there that left many deposits.  These deposits would form false seals that would close off the oil to the original seal causing it to be destroyed, but the false seal would keep it from/slow the leak down.  When you put synthetic oil in, it cleaned the deposits and broke down the false seal.  Then those not knowing any better blamed the synthetics for causing the leak.
Modern dino oils are where synthetics were 15years ago do the the increasingly stringent specifications.  So you don't see the false seals happening with vehicles now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2010 at 9:27am
I don't know why BWP was trying straight 15w in that motor, should have been 5W-30 at least in if not 5W-40 if it has many miles on it.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2010 at 9:51am
I use motor oil for less weight on the puller.
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2010 at 9:57am
thanks everyone...when i brought the oil,i did not realize it was synthetic till i got it home.i am going to return it and get the petroliem based oil,i know the old geesers will like it...
