Allis chalmers 172 mower parts
Jamesfwilde View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamesfwilde Quote  Post ReplyReply Direct Link To This Post Topic: Allis chalmers 172 mower parts
    Posted: 10 Aug 2024 at 8:16pm
Need Allis chalmers 172 mower parts, need bearings
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2024 at 8:27pm
Welcome to forum. Do you have part numbers or better description of what you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamesfwilde Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2024 at 8:31pm
I could pick out the bearing if someone would post the parts breakdown on the shaft that drives the blades. I think it’s the carriage bearing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2024 at 9:40pm
In the gearbox or pto shaft
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamesfwilde Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2024 at 5:50am
P T O shaft
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2024 at 8:00pm
If your just needing the carrier bearing. It’s available. If you don’t have a local agco dealer to work with we can help you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamesfwilde Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2024 at 8:18pm
I took it apart today, I just need the bearing. Would you have the part number. Thanks
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2024 at 8:33pm
71132366 for the carrier bearing.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamesfwilde Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2024 at 8:42pm
The bearing was pretty messed up and wore a grove in the p t o shaft. Is the bearing the only thing I need, there isn’t any seals? I may have to take the p t o to a machinist and build back up.
