7020 - Steering Hydraulic Cylinder Fix
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Topic: 7020 - Steering Hydraulic Cylinder Fix
    Posted: 09 Aug 2024 at 3:50pm
Have a bad leak on the hydraulic steering cylinder.  I have bought the seal kit from agco and going to try it.  Hope there isn't any major rod issues.
My only cylinder rebuild experience is that I have rebuilt the 4 cylinders on the 500 loader, buy maybe this cylinder is easier or harder?  Any tricks to rebuilding this cylinder that I should know about?
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2024 at 6:17pm
I took the retainer ring off, item 12, but I can't figure out how to pull the piston out?  I don't see the snap ring they refer to which is item 11?  I tried unscrewing it thinking it had threads and it just turns.  So, no threads.  Anyone know how does the piston come out?
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2024 at 6:23pm
Not difficult. Will need to tap the gland head in a little to remove snap ring IIRC. Did 3 on the tractor only removing one end and the hoses. I thoroughly cleaned the dirt and rust on the end before inserting the New seals. I do not know what or if there is a torque spec for the locknut on the shaft end
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2024 at 6:29pm
So, I have tapped the gland head inwards but it stops before it exposes the retaining ring?  I haven't hit it hard.  Do I need to hit a little harder?  It just feels like something is jammed behind it that shouldn't be there.  Not sure what that could be though.
Edited by calico190xt68 - 09 Aug 2024 at 6:37pm
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2024 at 9:38pm
Make sure that the rod is partially retracted into the barrel so that the gland isn't hitting the piston, which is on the end of the rod. Yes, tap the gland into the barrel to gain access to the round ring. Then pull it out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2024 at 10:02pm
I did mine some time ago. I recently acquired a service manual and found the page in question
And lo and behold, there is a torque spec for the rod nut
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2024 at 9:24am
Thanks for the diagram.  I went out this morning and tapped the piston and it went right in and exposed the snap ring.  I don't know what the problem was yesterday.  I did position the rod half in the middle as Lynn suggested so maybe that was it.  My new problem is getting the tube inserted into rod.  The yellow retaining ring keeps wanting to get into a bind as the tube is inserted.  Is there a trick to keeping the retaining ring together while inserting the tube?  This is the last thing.
I noticed this pitting on the rod.  Maybe I need a new rod?
This yellow retaining ring is really loose and hard to keep in place.  What is the trick?
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2024 at 4:23pm
I put a hose clamp around it and snugged it down. Held it there for a while. Overnight on a couple. Put one from a skid loader in the freezer once so it would hold shape after I removed the clamp. If you have a ring compressor, even better as there is no groove for the worm gear to leave impressions in the new seal. This is why I spent cleaning any rust off the end of the bore
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2024 at 4:27pm
Pits are nasty. One of mine, the PO or his mechanic appeared to have cranked on the rod with a pipe wrench. I smoothed it up with file and sand cloth. Still have some groove marks butisnot leaking
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2024 at 9:02pm
Well. I failed. My cylimder won't move either direction. It nudges then stops. If it isn't connected it will extend but not retract. I found an oring was damaged when i took it apart. I screwed up that retaining ring too. Going to have to put the tail between the legs and get a professional.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2024 at 1:44am
You didnt fail. It just didnt work this time
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
ValleyFarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ValleyFarm Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2024 at 7:01am
Did you try cracking the lines and bleeding the air out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2024 at 10:31am
I did, but I screwed up other parts of it.  I can't get the retaining ring in no matter what.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2024 at 1:50pm
After analysis by hydraulic shop, the tube needed to be honed.  The pitted piston needed to be replaced or it was just going to keep ruining my seals.  Seals weren't the only problem.  Agco does not have pistons nor tubes for sale any longer.  I know All States Ag had a used steering cylinder for sale at $209 but it could have the same problem.
Just a new seal kit would not have fixed my problems in the long run.
I need to do the same thing to the 7010 although it doesn't leak near as bad.  I will see how this goes and then maybe do that one this winter.
Hope it is fixed in two days as the shop indicated.  Got some hay I need to get cut and baled.
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2024 at 3:10pm
Glad you’re able to identify the cause and have it repaired. Curious as to how the rod got so beat up
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2024 at 3:50pm
I have owned the tractor for about 5 days so i dont know the history as it was bought at auction. Doesn't look like a wrench in my opinion. It was leaking really badly. After driving down road, the rear tire was soaked. We put 5 gallons in it. Hoping this is the only major problem. Thanks for your help on this!
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2024 at 5:33pm
I got the cylinder back from the hydro shop. Works great, no leaks. They said it was also bent as well as the pitting on the piston. Hard to understand how a steering cylinder would get bent? That's a heavy duty piston. Need to get the 7010 cylinder fixed next. Steering is way better on 7020.
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2024 at 5:49pm
That is a stout piston but who knows what that tractor has been through. Just ask JWingerter about his D17. Yours may have been abused in a previous life. Glad you got it back and working. Sorry it turned out to be more than a DIY fix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2024 at 10:20pm
I would think something else would break before that piston would bend but i don't know the history. I wasted $87 trying to fix it myself but i really wanted to use it this past weekend. It is a relief knowing it is fixed right. Should last another 45 years. I was going to lose another $100 in hydro fluid per day of use if i didnt fix it. Still shaking it out and see some small things i need to do. Fuel shutoff cable is not oem and cheap. It flexes and won't cut off the fuel everytime. It is never ending with old stuff but i like having a spare tractor and not spending $50k.
This page was generated in 0.308 seconds.
