grain cart tire pressure
cowkicker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Topic: grain cart tire pressure
    Posted: 04 Aug 2024 at 8:53pm
What would be the recommended  pressure for a 14.00x20 tire on a 400 bu grain cart? They are the old military style tread design. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2024 at 9:12pm
Forgot to mention that tires are old and dry, just going to use it sometimes to move some feed around, dont want to put too much in them and blow them out before I start
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2024 at 9:36pm
since they are old and dry rot, i would not go over 30 psi.... might try 20 psi  and see how they look with a small load.. The LOWEST pressure you can use and still keep a decent amount of tread on the ground would be the bests bet..... many military tires are rated at 50 psi.. for MAX LOAD.
Edited by steve(ill) - 04 Aug 2024 at 9:43pm
This page was generated in 3.305 seconds.
