Early Pull Type Combine - Rounded Sheet Metal
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Topic: Early Pull Type Combine - Rounded Sheet Metal
    Posted: 04 Aug 2024 at 10:06am
I came across an early combine in a fence row. It's been outside for years, but it is one of the early ones with the rounded sheet metal. Sorry, I did not get a chance to take pictures and didn't know where to find the serial number on these earlier machines at the time (I do now after some internet research).
In order to get it home I would have to get the spoke wheels off and have new tires put on, and drag it ~100 miles home. The guy wanted me to come pull any parts I wanted off of it before he scraps it, but now I'm wondering if I should try to save the whole combine. It has the rounded sheet metal, elevator inside the bin, and a whole bunch of other little things unique to the earlier harvesters.
My limit in the past has been about 20 miles for dragging them home.
I'm not sure how unique these are other than I have only ever seen the one in person at Hutchinson. I found a few other posts on the forum where guys had a handful. Is it worth the trouble of dragging the whole thing home to save it?
Edited by wjohn - 04 Aug 2024 at 11:24am
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2024 at 1:12pm
Well if it gets scraped it will be one less on the earth…
Is it an All Crop?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2024 at 2:38pm
Is it an All Crop?
I did not want to refer to it as an All-Crop because I am not sure of the serial number, but more or less, yes. They didn't start calling them "All-Crop Harvesters" until 1936 or so from what I have read on here and seen in literature. The earlier ones were called "High Speed Combines."
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2024 at 3:36pm
This the beastie?
Made in '38, '39, and '40, 15,000 or more of them...
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2024 at 3:54pm
This the beastie?
No sir, not a 40. This combine is one of the earlier ones that eventually became called the 60.
It's like what is shown at this timestamp here:
Herb(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2024 at 6:46pm
Drag/Pull it home.  You may decide it was not worthwhile; but you will always wonder  (if you don't bring it home).   Herb(GA)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2024 at 10:59pm
I found this, hope it helps!!! https://www.allischalmers.com/forum/hauling-a-combine_topic126084.html
Edited by 55allis - 04 Aug 2024 at 11:01pm
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2024 at 6:12am
Good luck with the combine, hope you can save it!
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2024 at 6:24am
The rounded ones where called a camelback. There was not an unloading auger, just a flip over spout. Can you get a picture from the history walk that was done at the Hutch show?
http://lonsallischalmers.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2024 at 11:57pm
Thanks guys!
Mike, would you drag it home? I'm not big on having stuff around that I wouldn't use, but I may have to bend the rules on this one. Did drag an okay looking 63 plow home today.
Lon, I didn't take any good pics of it while I was there (sure wish I had now!) but I did find some neat ones on the internet. Here's one of them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2024 at 5:51am
That is a camel back. very early and hard to find. Does it have the square tube above the cylinder like in the picture?
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2024 at 8:03am
I probably would not, hate to see it go to scrap but those things take up a lot of space. Pull type combines really aren't 'my thing'. And, I've got a backlog of projects around here about a mile long already!
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2024 at 6:27pm
I don't think it did. From what I was able to find, that was something they did a recall on, or changed very early on in production?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2024 at 7:05am
If you are up to saving it, Always a project moving a combine. It is rare.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2024 at 11:24am
A High Speed/All-Crop Harvester has been on my “want to find” list for some time, but as Lon has said, they are rare. They have their nuances that make them inconvenient and antiquated compared to the model 60s even just a few years newer, so a lot were scrapped. Would be great to see some photos of it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2024 at 11:28am
Yes, the 1935 High Speed and the 1936 All-Crop Harvester had it, it’s a re-cleaning device for the tailings. The 1937 All-Crop did not have it, as they tended to shake apart. “Camelback” is a common term people use for the combines but it’s a slang rather than official title.
Edited by CrestonM - 07 Aug 2024 at 11:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2024 at 6:50pm
You guys sure are enablers. I was hoping to hear that there were hundreds of these still hanging around and I could just steal parts and let it go to the crusher. Guess I will see if I can get the thing jacked up to pull the spoked wheels off, and get some tires put on if the rims are still okay.
Towing it at 20-25 MPH will make for a long afternoon if it can make the trip.
Edited by wjohn - 07 Aug 2024 at 6:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2024 at 9:46pm
Your best bet will be to get new tires for the spoked wheels if the rims are good. You can put later model 60 rims on but you have to change the hub also. These combines didn’t have wheel bearings but rather brass bushings, so make sure you grease them well and probably be best to stay under 30 mph. Grease is your friend with these hubs, I’d give them a few shots every 15 miles if it was me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2025 at 10:46pm
A good while later... I finally got it home today. It's rough and missing plenty of things, but I'm hoping with another one I could make a good early-ish combine. Wheels are good, header is pretty good, and the unloading elevator seems to be decent. Is that the serial number (11432)? It's stamped on the LH side of the combine near the cylinder, close to where it is on the newer 60s. The "7-" part is throwing me off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2025 at 12:01am
I might know of one in a creek near me…
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2025 at 5:51pm
I remember your post on those! Too bad they're not closer... those are exactly the sort of combines that combined (pun intended?) with mine might have enough decent parts to make a good one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2025 at 9:35pm
How “legal” was you when you hauled yours on the trailer?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2025 at 5:22pm
No issues (disclaimer - everyone do your own research on your own state's rules for transporting ag equipment). I was under height but over 102" wide, so I only would've needed a permit if I had to go on the interstate here. I did not have to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2025 at 6:16pm
How is the wood in your?
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2025 at 9:18pm
Ya know,, for as long as it's been settin,, it don't look THAT bad,, but the pictures don't really show the places where they really like to rust out.
Good luck with you new toy!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2025 at 10:07pm
The wood is rough and the cleaning shoe is actually entirely gone. The concave sheet metal is gone and some of the other low spots are rusted through as well. I need to take some better pictures tomorrow so it is clear how much of a heap it is. It also had a tree or something fall on the top part of the straw walker housing.
On the plus side I did get 1/12" (red/white clovers and turnips) and 3/8" (soybean) screens with it, which I didn't have yet.
Priority wise, this thing will probably sit until I find another. I'd rather get my newer 60 functioning first anyhow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2025 at 10:53pm
Could you get some pictures of the screens?
I’d like to see them to know what I need for my 60A, I don’t think mine has any screens (set for oats).
I’d love to combine some soybeans with it when I get it going!!
I can look to see what is still good on the two in the creek when I go down there.
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2025 at 8:33am
I'm late to this discussion. There is what appears to be unrestored original All Crop on display at The National Ag Hall of Fame & Museum in Bonner Springs, KS. I volunteer there & the place has been there 60 yrs.  Anyway, here is the wording placard description. "In 1930, Californians Robert Fleming & Guy Hall demonstrated their combine in Kenosha County, Wisconsin.  Harry Merritt, Allis Chalmers' chief engineer, paid them $25,000. for the rights to produce this smallest-ever combine. Distinguishing features of this "baby combine" were its small size, lightweight 'scoop shovel' front end and full width wire brush cylinder.
Beginning in 1932, Allis Chalmers replaced wire brushes with rubber-covered angle bars that provided a resilient flailing action on the grain without chewing up the straw. Further adaption involved replacing link chain with rubber V-belts.  The Model 60, debuting in 1932, weighed 2800 lbs, cut 5.5 ft. swath, and was mounted on pneumatic tires. The Model 60 could be pulled & powered with ease from the pto of a 2-plow tractor. In 1936, 8,000 Model 60's were sold for $595. each. In comparison, the Model 40 sold for $345. when it first appeared on the market in 1938"
I'm not sure of the origine of this item but might be able to find out. It's parked alongside of a cutaway Gleaner self-propelled donated by Gleaner back in the glory days.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2025 at 10:29am
Unfortunately, it looks like your serial number is gone. It would be stamped on this angle iron piece in front of the bin. Looking at your machine, however, it's a 1937 model since it doesn't have the patched hole behind the cylinder where the original tailings recleaner  grain return would've been on the 1935-1936 machines.
The number you found by the cylinder, if that were a serial number, would place it as a mid-1936, which doesn't seem right, and the 7 in front throws me off as well. I'll check my machine again and see if it's got a number stamped in that location, but I don't recall seeing one there on the machines I've looked at.
Edited by CrestonM - 10 Oct 2025 at 10:34am
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2025 at 9:17am
I'll try to remember to get some next time I'm out there, but they look just like any others. There are some decent screen pictures if you look through the images in this auction listing: https://www.auctiontime.com/listing/auction-results/233571437/allis-chalmers-60-combines-harvesters
