2000 plow
Indiana7040 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Indiana7040 Quote  Post ReplyReply Direct Link To This Post Topic: 2000 plow
    Posted: 02 Aug 2024 at 6:28pm
Hi first time posting here so I’m sure I’m not doing it right. I have a question about my 2000 plow. It’s a 5-16 trip reset and it has cast iron land slides that bolts directly to the frog instead of an inner slide and a wear pad. My cast iron ones are stamped wiese 354w. I’ve done a lot of looking and can’t find any similar replacements. Thanks in advance     Also. Were these an aftermarket upgrade or what’s the point of these vs the two piece style
Edited by Indiana7040 - 02 Aug 2024 at 6:48pm
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2024 at 6:44pm
Try Dave the plowman
A search on the internet should bring him up
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Indiana7040 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2024 at 6:49pm
Seems he only deals in snap coupler plows
Edited by Indiana7040 - 02 Aug 2024 at 7:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2024 at 8:51pm
Ive got a 7 bottom on the land model 3000 plow with 387 bottoms and I got shares and landsides from him
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2024 at 9:45pm
Send me a private message with your email or phone number. Have some pictures of parts book and we can see if can figure which bottom you have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2024 at 6:15pm
The first thing that is needed is to determine which bottom you have as any bottom made by Allis Chalmers will bolt onto any plow frame built by Allis Chalmers.
  In today's world the 387 bottom is the only bottom that there is any supply of NEW aftermarket parts for on a scale basis. There are a lot of NOS parts available if you can find what you need. Yes Dave-The-Plowman has lots of parts for Allis plows and he is even have a few things made.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Indiana7040 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2024 at 9:17pm
How do I locate the number bottom I have ? I’m assuming I’m looking for a 3 digit number on the frog somewhere?   I did order a new share from shoup for a 387 and it bolted right on. So does that mean it’s a 387. Or are some of the parts interchangeable? I’m far from a plow expert. My dad stopped plowing and sold the plows long before I was born.
Edited by Indiana7040 - 03 Aug 2024 at 9:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2024 at 9:37pm
Is your landslide single or double bolt. And are they plow bolt or 5/8 bolt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Indiana7040 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2024 at 9:45pm
My landslides have two bolts. One at the front that looks to be a 5/8 plow bolt and then one up top I believe is a 7/16 hex bolt
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2024 at 6:54am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2024 at 7:32am
There’s a lot of good info there but didn’t see any for his model plow.
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2024 at 7:38am
"2000" series plows I've been around have #387 bottoms and have 387 stamped on back side of moldboard. Try Manchester Farm Supply @ North Manchester, In. for plow parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2024 at 1:42pm
387's have a look of their own. Short and stubby? Not long and twisty. They turn dirt like no other.
This page was generated in 0.095 seconds.
