Replace fuel sender on 7040
jazzsuds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jazzsuds Quote  Post ReplyReply Direct Link To This Post Topic: Replace fuel sender on 7040
    Posted: 29 Jul 2024 at 7:20pm
Hi folks
Can someone tell me in detail steps how to replace the fuel sender on my 7040?
Thanks
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2024 at 10:03pm
Get the floor mat moved out of the way in the front left corner of the cab. There's an access hole cover there that just pops up with screwdriver. Clean the area well. Remote the small nut that has the signal wire on it. Now remove the screws that hold the sender in the tank. One of them has the ground wire on it. The sender can now be taken out the top. You have to gently bend the float rod a little bit for it to come out. Assemble in reverse order. The float rod will need to be bent some on a new sender and then straightened back once you get it into the tank hole. The sender screw holes and gasket are offset enough so that it will only line up one way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jazzsuds Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2024 at 11:54am
Thanks Lynn. My tractor has no cab and no floor trap door to access. Its just a steel floor and it appears i have to remove it to get to the fuel tank top
Edited by jazzsuds - 30 Jul 2024 at 11:54am
