Wd fuel issues?
JohnCinMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Topic: Wd fuel issues?
    Posted: 28 Jul 2024 at 9:52am
Was driving the WD to a tractor ride this morning when she starting sputtering, losing power, then finally quit. Wouldn't restart. Tank is half full, but it hasn't run in about 5 months. The bowl had crap in the bottom. I'm going to drain the tank, then inspect the fuel line & carb. Am I on the right track?
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2024 at 10:08am
I'd say yes. With the bowl off, check for good flow from the tank
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2024 at 4:02pm
If it is a fuel issue, the inlet of the sediment bowl is probably plugged with rust and dirt. If that is the case, the tank will probably have to be drained and the sediment bowl removed to clean it.
It's a good chance to shine a light in the fuel tank to see what it looks like. If it's rusty, you might want to clean it before reinstalling the sediment bowl.
Your problem could be a bad coil or condensor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2024 at 5:42pm
If you have Ethenol in the fuel in your area, that could be the cause, especially since it sat for 5 or so months. Plenty of time for the Ethenol to separate and make muck in the bowl of the Carb or the fuel tank. Wouldn't rule out the possible Condenser issue either. Then little buggers cause the same type of issue.....
Steve@B&B
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2024 at 6:39pm
Last tank before parking should be "rec fuel" or recreation fuel that has no ethanol. Fuel stabilizers do nothing.
