Injector seat cleaning 670T |
Post Reply |
rmullican
Bronze Level Joined: 17 Jan 2017 Location: McMinnville, TN Points: 38 |
Posted: 28 Jul 2024 at 8:39am |
I am in process of pulling injectors and will be getting pump rebuilt on 670T from my 8030. What is a good way of cleaning injector seats with head still on engine?
170 W/FEL, 7010 PD, 8030 FWA PS
8070nc
Silver Level Access Joined: 21 Mar 2019 Location: North Carolina Points: 498 |
Somebody may have a better way but id plumb a air line into the intake manifold with some way to control flow. Air will come out which ever cylinder the intake valve is open on. Air flowing out will help prevent debris from falling on a piston
Take a round brush on a drill a little larger than the injector hole and clean the hole with air coming out. Rotate the engine until air comes out a different cylinder. Cleann that one and continue the process until you have done them all |
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8158 |
The seat is the copper washer. Shouldn't require much cleaning just replacing washer.
rmullican
Thanks for the replies, all the copper washers are out and I plan on replacing those. Just trying to get an idea on how to clean the crud out of the injector holes without it dropping into cylinders.
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 8091 |
Well what I do is, blow it off with air before, but ; Id just be careful to watch so not much stuff gets in there, that concave copper washer seals everything ; shouldnt be no big deal,,
SteveM C/IL
I suppose you could drop a short bolt in the hole then scrape around the bore to "clean" it then hold down on bolt while blasting air in there to purge hole. Finally use pen magnet to pull bolt out. Were the rubber dirt seals missing on old injectors?
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4859 |
I use a long skinny screwdriver to scrape the carbon off the bottom, wire brush in the bore if needed, then brakleen it, blow dry, some will go in the cyl, but will be blown out right away, it's not like you're dropping huge chunks in there.
rmullican
Thanks everyone, the rubber dust shields were in place, just looking to clean up the flaking rust from bore where injector slides in. Looks like tractor has sat outside for some time as injectors were kind of rusted in place. Top surface of head I was able to get reasonably clean. Plan is to use big shop vac and wire brush to clean up bore and the address any carbon build up on seat where copper washer sets
Lynn Marshall
Orange Level Access Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2257 |
After cleaning the holes, I usually spin the engine over with the starter to hopefully blow any foreign material out of the cylinders.
Post Reply | |
