Engine Cleanup - opinions
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Topic: Engine Cleanup - opinions
    Posted: 27 Jul 2024 at 9:11am
Working on D14 project that sat around for many years.   Engine always started and ran Ok but when I drained old oil, I noticed a lot of waxy lumps dropped out.  I dropped oil pan and basically deposits all over in there.   Probably never ran long enough over the years to burn out moisture.
I pulled head and one piston, all looks good except for those crappy deposits on everything.
Plan to clean up everything I can see without further disassembly.  Will lap valves a bit but they look fine.   Probably just pop the piston back in and not touch anything on lower end or front gear cover.
I have a little JD diesel now and was planning to start using conventional diesel oil 15W40.   Some say it is good for old tractor engines.   I don't have a good way to load engine but may just let it run a long time this summer to make sure to get oil warmed good, then drain that oil right away.   Old Norm used to say run a bush hog to load em up good but I don't have anything suitable.
If anyone has opinions, suggestions let me know.   Thank you.
AC7060IL View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2024 at 10:12am
Here’s one of my previous post about removing engine oil sludge from a vehicle’s engine. As for your tractor ~ synthetic blend oil / conventional oil recipe would probably help with frequent oil change intervals(OCI)? Obviously, good lengthy durations of engine operation should benefit it too.
Maybe start by checking D14’s breather apparatus (blow-by tube from its valve cover?). Make sure it’s open & able to function. Seen mud dauber wasps built mud nests in tube, clog it shut, & engine quits breathing. Kinda similar to vehicle engines where their PCV (positive crankcase ventilation)for breathing fails. Too lengthy of OCI could cause PCV failure & then sludge begins.
https://www.allischalmers.com/forum/conv-synthetic-blend-recipe_topic200515.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2024 at 10:27am
I had been buying conventional diesel oil, there are a few still out there.   Was a little leery of synthetic with the old seals and filters.
The D14 is a simple breather cap.  I saw the manual suggested cleaning it every 8 hours, daily LOL.   I will try to clean it good.
I noted the Baldwin filter still looks to be old type fiber element.  I think that is all you can get that fit the fruit jar thread base used on the old ACs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2024 at 12:07pm
That’s the beauty of an oil recipe. Use same viscosity in all oils. Try SOME synthetic blend(1-2qts?, 3qts?) mixed with conventional oi(1-2qts?, or whatever?).
While D14’s oil pan is off, check/clean oil sump. If it’s got a screen, inspect/clean it. If it doesn’t contain a screen, consider installing one to help catch sludge. Every OCI drop oil pan & inspect/clean for sludge/debris.
Synthetic blend helps “wash” engine.
When engine is running, try to catch condensation(H2O) emissions from breather to understand what’s happening. Compare levels as OCI progress. If possible use a longer oil filter for increased capacity?
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2024 at 1:04pm
there's still a good choice of the old style filters, here's a few popular ones
Oil Filter
AGCO - (70)240912
Wix - 57011
NAPA - 7011
Fleetguard - LF571
Fram - C159
Baldwin - T300M
Carquest - 84011
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (1) Thanks(1)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2024 at 1:20pm
To create a load cycle on engine, try covering entire front of radiator to limit coolant fan from pulling air thru radiator. And,,, set throttle at high idle??
Keep an eye on coolant temp gauge to keep needle out of red zone. Recommend using an Infared Thermometer with laser targeting to know engine temps during load cycles. Laser can pinpoint different areas of radiator hoses, front of head, back of head, etc so you can know extremes.
Any type of pto equipment that can be added during radiator covering load would help increase load.
Or if no pto equipment, then drive it around in higher gears and up hills(grades).
Assumed you’ve already checked that coolant isn’t leaking into oil??
https://m.youtube.com/watch?v=KoT-PWg8Ahs&pp=QAFIAg%3D%3D
Edited by AC7060IL - 27 Jul 2024 at 1:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2024 at 10:49am
yeah good point, while I have pan off I will add coolant and check for obvious leaks before I button back up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2024 at 10:57am
I’m suggesting to inspect/clean engine’s crankcase oil vent. I don’t have a D14, so I searched online about it. Others on forum please correct me, but I think the D14 engine has an oil fill cap that has its vent built into it? It consist of a cap/canister filled with fine stainless steel curls where engine’s blow-by gases can escape to atmosphere. If so, that may need attention/cleaned to assist engine’s crankcase gases to breath? For a healthy engine, this item may never require cleaning. But we are talking decades since new, so yes definitely pressure test it to verify that air/gases can pass thru it.
From your reply, I think you’re talking engine air intake filter? If so, I think D14 uses an oil bath filter for that? If so, then yes, it should be serviced every 8 hrs in dusty conditions.
Edited by AC7060IL - 29 Jul 2024 at 11:11am
