1982 ALLIS CHALMERS - 7010-592042
SMRDIESEL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SMRDIESEL Quote  Post ReplyReply Direct Link To This Post Topic: 1982 ALLIS CHALMERS - 7010-592042
    Posted: 22 Jul 2024 at 1:54pm
Can Someone help me with the Diagram or how the clutch return spring works?
the clutch pedal is all the way down. it's a hydraulic clutch and there is a lever on the right side. i push that lever and the clutch pedal returns to the top.
does the tractor need to be running  in order for hydraulics to kick in and push the piston back ?
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2024 at 4:58pm
There is a clutch pedal return spring above the clutch pedal inside the instrument panel. The left orange colored panel must be removed to access it, after removing the lower black or brown panel first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SMRDIESEL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2024 at 5:37pm
So the clutch return spring would hold the pedal up and keep the piston pushed in?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2024 at 5:41pm
Yup. They break these return springs. Nothing new.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SMRDIESEL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2024 at 5:42pm
this is the lever i am talking about
Post Options Post Options   Thanks (0) Thanks(0)   Quote SMRDIESEL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2024 at 5:45pm
we have to take the cab off to replace the return spring?
would you have the instructions?
i really appriciate your help!
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2024 at 6:05pm
I never said anything about removing the cab. Remove both left and right hoods. Remove the short rear center top hood by releasing the spring hooks.  Standing on the ground, open the cab door. Remove the metal strip holding down the floor mat and roll the floor mat back under the seat. Remove the black side panel that is straight in front of you. Remove some of the bolts to the black panel above the steering wheel tilt release. Now, your goal is to remove the LEFT orange side panel above the clutch pedal. This takes more bolt removal and probably another top panel to the instrument panel. The broken spring is inside that orange panel and above the clutch pedal.
Edited by DrAllis - 22 Jul 2024 at 6:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2024 at 6:25pm
How does info that was straight forward - replacing a spring- turn into taking the cab off ETC,,,, maybe I missed something, geesh
