Hutch wish list, ISO..pictures added
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Topic: Hutch wish list, ISO..pictures added
    Posted: 20 Jul 2024 at 10:28am
looking for some 190 stuff and pin hitch WD implements..
for the 190,
2 front hubs, PN 71261418
1 hub cap, 70220403
1 wheel, I hope I can find one that matches, 70257789 best I can measure on the tractor this is a 16 X8" fits 10:00 X 16 tire,  6 lug, with a 0 or 1/8" offset, I have pictures,, may edit/add later...
WD pin hitch equipment,, looking for most anything,, only requirement,, its got to fit in a long bed pick-up
I may add more
Edited by Michael V (NM) - 20 Jul 2024 at 9:12pm
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2024 at 6:45am
I have two roll over plows.
http://lonsallischalmers.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2024 at 6:50am
I have this hitch available for the two row drill planter, that is for WD pin hitch tractors.
I will not be coming to Hutch. Maybe you could find a way you get it to you. I'm located In north central Maryland.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2024 at 7:52am
Paul, thanks. But looking for complete implements
Lon, I have one of those..jus needs coulters,and pin hitch hookups...has S-C on it now...
Still looking for the wheel...
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2024 at 10:51am
If you had this hitch, you would not pass on a two row planter just because it didn't have a WD pin-hitch for your tractor. Two bolts and then you would have a WD pin hitch planter.
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2024 at 9:21am
have new hubs and caps wheel bearing kits , will look for rim thanks Steve 507 766 0551
This page was generated in 0.330 seconds.
