farm storage building width
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Topic: farm storage building width
    Posted: 19 Jul 2024 at 12:51pm
Lot of brands have a 60 x 100? kinda standard building. Question is would 66 wide be a plus or a waste? Size of what you put in it matters I realize. Thinking big wide sliding doors on each end nothing on the wall. Park/stack stuff along the walls. Just seems the extra width would gain better access down the isle. Thoughts?
Edited by SteveM C/IL - 19 Jul 2024 at 3:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2024 at 12:54pm
sketch it out on a piece of paper... a lot depends on what is in the ROWS... WD45 or Combines ?   Area needed for SHOP space and TOOL ROOM , PARTS ROOM..
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2024 at 1:12pm
Was always told, to plan and draw out what you need, and what you believe in your head would be ‘big enough’, then expand by 50%. In a year after completion you will curse yourself for not doubling the size.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2024 at 2:53pm
mine is a  60 x 120 Alaska building ( Alaska order fell thru so I got this one at a discount.) I was told that  IF you go any wider than 60 you have to have center posts which then are in the way and you lose space trying to drive/park/work around them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2024 at 3:23pm
Make it round.  That way schitt won't build up in the corners...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2024 at 3:46pm
and...
you could have a turntable  in the center !
That way you never have to back out of the building !!!
Just think 'old skool' RR Roundhouse...
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2024 at 5:37pm
Depending on builder, brother has 80 feet wide with no center poles, get as big as you can afford and have room for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2024 at 6:13pm
Seems the truss load in each area might vary - what is snow load rated in your area ?
End only access limits use some then depending what your storing is the big question .
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2024 at 6:27pm
I'd lay it out too and draw out your big stuff (combine? semi? etc.) and see how the width looks.
Another way to think about the extra 3' on either side might be that it's room for 3' deep shelves wherever you want around the perimeter.
The shop on the place I bought has an overhead door very close to one side wall, and I can't store hardly anything along that wall because then I couldn't pull a truck in. There's some wasted space there that would be usable if it were even another 2' past the edge of the door. I like shelves for parts etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2024 at 7:49pm
Built two 30x48 buildings thinking of area constraints, should have tossed that consideration and built 50x100 BOTH times, would Still be too small.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2024 at 10:24pm
If possible go wider with building. Also consider adding a lean to onto larger building for all your shop tools, welding/fab area, shelves, parts, wash bay/pad, pickup/tool truck parking, etc. Lean to’s ceiling is usually lower so it can provide better lighting, more comfortable heat/cooling, etc & does not take away any “high dollar” taller shed storage space. Any larger machinery can then be situated near shop
(Interior/Exterior) to accommodate most repairs.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2024 at 11:24pm
Over 60 feet they charge more for trusses to carry the load. Depends on what equipment and it size. But if you had a door in the side and you were going to back a semi tractor and trailer in you would want extra width. I would recommend two 15 foot doors for a 30 ft opening. That way you can park things right around the corner.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2024 at 12:56am
Setup a scale for the bldg and its contents, I used 1" equals 1'.
(I made all tractors, trucks, etc., & shop equipment mostly squares or rectangles from cardboard, I labeled them track what they all were.)
Then draw it out until the necessities fit inside, get a few quotes to build it. After you recover from the sticker shock, then start scaling down building to payments you can live with.
 I used a sheet of OSB and longer stick pins to hold the cardboards to it.
 It's 48x60x16' and YES it was "too small" the day we started on the wiring and lights.
But it sure beats doing equipment and vehicle repairs outside in any weather on dirt or an old hog feeding slab like I did for 25+ years on 3 bldg sites.
 IMHO, "Build it now, it'll never get cheaper to build, and will save on equip maint costs."
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2024 at 7:04pm
AC has the idea.. Build your STORAGE BUILDING, ( just posts, no tin on one side ) then put a 10 ft wide lean to on one side with a 8- 10 ft ceiling.. Make that the PARTS , WELDING, MACHINE SHOP, etc... Much cheaper !!! .... and you can do the OTHER side at a later date,  if you need more than 100 ft !!
Edited by steve(ill) - 20 Jul 2024 at 7:06pm
This page was generated in 0.191 seconds.
