WC Water Pump Replacement Question
Brendan (AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brendan (AB) Quote  Post ReplyReply Direct Link To This Post Topic: WC Water Pump Replacement Question
    Posted: 16 Jul 2024 at 8:25am
I need to replace the water pump on my WC. The new pump came with a paper gasket. My question is do I need to use any sealer when installing the gasket and pump, or do I just put it together dry? And if sealer is necessary, what should I use? Thanks.
Tom IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom IA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2024 at 10:15am
I always use sealer older surface can be rough hit with file use non hardening permatex
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2024 at 11:52am
#2 permatex non hardening gasket sealer works well. Permatex also makes a spefic sealer for antifreeze but I odn't think it's necessary.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2024 at 5:39pm
Yup, #2 Permatex for when you really don't want to take it right back apart. Which is most of the time. 50 years from now, someone will think unkind thoughts about you as they are scraping it off Big smile
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2024 at 6:33pm
I could wonder if the maker/rebuilder of these pumps use any gasket sealer or if they do what kind?  I have had the rear cover leak on two of these new pumps, just after installation.
This page was generated in 0.045 seconds.
