pertonix and spark plugs
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: pertonix and spark plugs
    Posted: 15 Jul 2024 at 1:37pm
pertronix ignition and resitstance wires (carbon)  , does it matter if the spark plugs are resitor plugs
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2024 at 1:40pm
what spark plug should i use in ad17 series iv with pertonix
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2024 at 1:46pm
I'm not aware of the need for resistor plugs with the Petronix ignitions. However think about this; A non-resistor plug will fire as soon as the voltage needed to jump the gap is reached, this could be high or low depending on what else is going on inside of the engine at any given time. A resistor plug must reach a specified voltage regardless of whatever is going on inside of the engine, thereby have a more precise control on ignition timing. If your considering what plugs to get for the puller you are building, I personally would use resistor plugs. Other opinions may vary.
  The only reason I use non-resistor plugs is with magnetos.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2024 at 2:19pm
AC Delco R45XL or R45XLS or equivalent.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2024 at 7:18am
Resistor plugs not needed. Just the wires as per Pertronix.
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2024 at 7:38am
that is was thinking about it all
This page was generated in 0.045 seconds.
