D17 valve adjustment
waw1962 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote waw1962 Quote  Post ReplyReply Direct Link To This Post Topic: D17 valve adjustment
    Posted: 15 Jul 2024 at 10:38am
The shop manual for the D17 series IV states to set valves 1,2,4, and 6 when TDC, then 3,5,7 and 8 at 90 degrees rotation of the crankshaft.  Others have stated to set them in firing order, 1,2,4 and 3.  Which is correct?  Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2024 at 11:23am
Either way works. Set ALL at .015" COLD which that book will not tell you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2024 at 7:10pm
90 degrees doesn't sound right....you better just do each cyl on TDC
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2024 at 11:26pm
one full rotation of the crankshaft.             two full turns on the crank = one full turn of the cam
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2024 at 6:49am
I haven't done many, but when I set them I just turn it over a few times watching and catch each valve when it's all the way closed. I don't worry about TDC and the firing order. These are pretty easy to do that way becasue duration is so short. They are fully closed most of the time.
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2024 at 7:01am
Take out spark plugs!
TDC on compression stroke.
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2024 at 11:08pm
Yep
Intake valve closes you are good to check valve clearance on both...
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2024 at 9:15am
4 cylinder overhead valve with the rocker cover off, it is pretty simple to watch the companion cylinder for the valves to be "on the rock" (exhaust valve closing and intake opening), to be in the correct place to set the valves on its cylinder with both valves closed, ready to fire.  1 and 4 are companions and 2 and 3 are companions.
Edited by Jim.ME - 18 Jul 2024 at 9:16am
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2024 at 9:27am
   Racer's set them the EOIC method, do each cylinder one at a time, as soon as the exhaust opens set the intake, as soon as the intake closes set the exhaust.
  I have used it for years.
