6080 thrust bearing adjustment
cowkicker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Topic: 6080 thrust bearing adjustment
    Posted: 10 Jul 2024 at 10:36am
I am in need of info on shimming the thrust bearing that mounts on the front of a 6080  engine. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2024 at 1:50pm
Google will shed some light.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2024 at 5:12pm
Thanks, but I was hoping for more info or a diect link.  I am not good with computers and have slow internet too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2024 at 5:28pm
Whenever I shimmed one I shot for .006" end play of the crankshaft. Shove the crank pulley to the rear as far as it will go with a prybar. Set your dial indicator at zero. Have someone step on the clutch pedal all the way and see what you've got.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2024 at 9:02pm
Thanks, that is what I was looking for!
