6080 still steering trouble..
rowtooe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rowtooe Quote  Post ReplyReply Direct Link To This Post Topic: 6080 still steering trouble..
    Posted: 01 Nov 2010 at 8:25pm
I have a 6080 AC.  I can turn to the left, the wheels turn nicely. When I try to turn to the right  the wheels do not turn easily, The steering wheel goes around but the wheels do not respond.. I have drained and refilled the rear end hydraulic oil, Cleaned the screen filter in the rear end, put on a new in line filter, Checked the spline on the hydraulic pump. Is it the steering control valve,, Could it be a bad cylinder on the front axle.. Any suggestions.. Thanks Pete
Steele View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steele Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2010 at 8:54pm
That happens to mine from time to time also.  Just turn it he other way and then it works again.  Has done this for years.  May not bother for months and then bothers a little and then goes away for months again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2010 at 9:45pm
Nut may have come off cylinder rod in steering cylinder.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote rowtooe Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2010 at 2:46pm
I removed the bucket loader and the hydraulic lines to the loader and it seemed to solve the steering problems..
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2010 at 4:54pm
hmmm, seems maybe the loader is hooked up wrong - could be flow divider stuck in pump as well.   Would have to have more input to troubleshoooot
This page was generated in 0.172 seconds.
