175 XTD first drive
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Topic: 175 XTD first drive
    Posted: 06 Jul 2024 at 7:28am
Going for a 17 mile drive to the local Pizza Ranch and then 17 miles back by another route. Son and grandsons are going as we will take the 175 XTD, the One-Seventy gas high deck, nephews D-15 II and the WD-45. Weather is to be perfect !! I tend to get my $$$$;s worth at Pizza Ranch and may need a nap half-way back home.
Edited by DrAllis - 06 Jul 2024 at 8:06am
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2024 at 9:18am
Safe travels to all
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2024 at 9:24am
Sounds like fun!! It is a beautiful day
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2024 at 3:05pm
SmileSmile
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2024 at 4:34pm
Safe trip. Everything worked fine. Beautiful day for a short all Allis ride !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2024 at 6:33pm
Going for a 17 mile drive to the local Pizza Ranch and then 17 miles back by another route. Son and grandsons are going as we will take the 175 XTD, the One-Seventy gas high deck, nephews D-15 II and the WD-45.<span style="white-space:pre">     </span>Weather is to be perfect !!<span style="white-space:pre">     </span>I tend to get my $$$$;s worth at Pizza Ranch and may need a nap half-way back home.
That is fantastic! What a great family memory and I really like hearing about the engine change. I wish I had your talents!
God bless you Tom and family,
Pastor Mike Townsley
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2024 at 6:35pm
That's about as close to heaven as you can get on earth!!!
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2024 at 6:52pm
Way to go DOC and Fam!
Blue Skies and Tail Winds
                          Dana
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2024 at 8:06pm
Doc, good for you, it was a beautiful yesterday and also today, glad you're back at it after last winter. Take care of yourself.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2024 at 8:19pm
I saw the picture on Facebook. You did a great job fitting the 433 in the 175 chassis. I love the work you do - it does not look hacked together! You take pride in your work.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2024 at 9:49pm
DrAllis, happy 4th of July, What a great way to enjoy family. Which of these tractor that you’ve listed is the fastest? Is the slowest? … in high gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2024 at 6:58am
If you run the WD-45 and the One-Seventy side-by-side down the road the WD-45 is just a tick faster with 14.9 x 28 rear tires. The One-Seventy has 15.5 x 38's and both engines are screaming at 2200 RPM. Actual speed is 17.0 to 17.3 MPH. The 175 is the slowest because it has 16.9 x 28 tires and 175's are equipped with 180/185 final drives for strength, but are 10% slower geared. I'd say it runs 16.5 MPH at 2500 RPM's as a guess.
kevin LA-CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevin LA-CA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2024 at 12:08pm
Dr. what have you done to the WD45 engine to safely run 2200? I think you have said swap governor spring to make rpm. I don't remember stock rpm.
Any other considerations for bearing clearances or oil pressure ? What about a running straight WD at this rpm?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2024 at 12:29pm
This high speed isn't to be used in the field !! It is only when I need extra ground speed to keep up with Farmall "M"s on a tractor ride. When I built the engine, I had the rotating assembly balanced. I also had a small groove ground into the very center of each main bearing journal to see to it the rod bearings would be getting oil 100% of the time instead of 1/3 of each revolution of the crankshaft. A D-17 governor spring is all it took to get the extra speed from 1,700 RPM to over 2,000 RPM. A WD is not much  different when it comes to the oiling system. I'd sure like it to have good oil pressure on the gauge before doing something like that. I know someone (an old deceased customer) who told me he used a D-17 governor spring on his WD with M&W pistons (60+ yrs ago) and the engine lasted one spring plowing season. The failure you ask ?? a rod bearing, from the lack of oiling that the 1/3 crank rotation gave to the rod bearings at 2000 RPM under a load.
Edited by DrAllis - 07 Jul 2024 at 1:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevin LA-CA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2024 at 8:06pm
Thanks Dr. Yes, tractor ride speed is what I was thinking. I didn't think about how crank bearing hole is only pressurized 1/3 of rotation.
Our old dealer said the WD engine would last with minimal pressure is you weren't plowing. Several of our machines run at N, but mostly parade duty.
Any value to the old rule of thumb of 10 psi per 1000 rpm? Where would that be on the gauge?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2024 at 8:18pm
The old rule of thumb might be OK for some engines but not for these.
bushnellman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bushnellman Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2024 at 12:43pm
Where can I get a D-17 governor spring, I looked with no luck
Can anyone ID these springs I have in my misc parts bin?
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2024 at 1:02pm
You've tried an AGCO dealership 70229519 is the p/n???  I'd say the top one might be to a D-17.
Edited by DrAllis - 08 Jul 2024 at 1:43pm
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2024 at 1:29pm
The D15 s2 is currently on 16.9x26 and I have clocked it at 20mph.......when I had 18.4x26 I hit 22.  both according to cell phone gps speedometers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 1:40pm
Yesterday got in 48 miles on a local tractor ride. Had 34 total participants. We took my WD-45, One-Seventy high deck and the 175XTD. Thanks to Kenny L. and my son Matt for a nice ride.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 8:29pm
I’m shocked over a 48 mile ride! I delivered at 175 this summer on a Sunday in the rain 10 miles which took me about 45 minutes I think and I was beat! But I don’t think I had it fire walled. But definitely a rough ride! Those culvert crossings can really rattle the front weights and ones teeth and spine! No way I could keep up with you road warriers😁!
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 9:05pm
Dr. it was my pleasure to be able to run the 175XTD and what great running tractor and just love cracking the throttle and seeing the smoke roll (sometime I'm like a little kid). As with any of your project you done a FANTASTIC job on the old girl.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 9:18pm
It's kind of like a baby Mack truck when it rolls the smoke !!!
This page was generated in 0.270 seconds.
