D17 Power Director
AjsAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AjsAllis Quote  Post ReplyReply Direct Link To This Post Topic: D17 Power Director
    Posted: 04 Jul 2024 at 11:09am
My power director doesn't seem to be working. When it's in neutral and I shift into any gear including reverse the trqctor begins moving. Is there something simple to fix here or is this a bigger task ?
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2024 at 2:41pm
If you push the brakes does it stop ?
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2024 at 2:47pm
They will do that with cold oil. Mine does the same thing when its cold but not after it warms up. The centering slot at the base if the handle could be out of adjustment. If after warming it up good you can hold the button down with the handle in the neutral position and gently move the handle back or forth and it stops you need to adjust the centering strap
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2024 at 3:56pm
These tractors don't get used every day like they used to . The discs and plates in the power director do not sit completely submerged. Corrosion or rust can occur when sitting idle for a while. Manual says to replace power director fluid every 500 hours or once a year. If not changed moisture can build up and cause Corrosion. Change the fluid in power director, go bale a few thousand small round bales with a roto baler. Change the fluid again and I bet she will coast to a stop when you slip it in neutral.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2024 at 9:30pm
D-series Power Director clutches "Creep" when in neutral. The creeping is worse with : Cold oil.....too heavy viscosity of oil (use Hy-Tran type)...1st gear versus 4th gear.....higher engine speed versus idle speed.  It is their nature to have some creeping and these are things that affect it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AjsAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2024 at 12:42pm
Thank you all who replied. That it indeed got better after warmed up.
This was my first time using in the field. It's really great to have a power director hay making.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2024 at 11:18am
They cannot be beat for running a small square baler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2024 at 11:38am
Ive got a series 4 and it does all things well
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote AjsAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2024 at 1:27pm
She's a good tractor I thought I should share a photo for the group.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2024 at 1:30pm
You didn't say it was a series 4 with a factory 3-point hitch !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2024 at 1:50pm
Mine is factory 3 point
1984 80780
1957 D14
616 tractor
