WD45 diesel questions
Allis Nation View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Nation Quote  Post ReplyReply Direct Link To This Post Topic: WD45 diesel questions
    Posted: 02 Jul 2024 at 8:56am
We recently bought a 45 diesel from a family member and he delivered it. It does start and run but only runs at one speed around idle. It also has fuel In the oil and after pulling the cover off the side of the pump it does have the normal bad o-ring. Could that be part of the issue of why it only idles or do I need to plan on pump and injectors being gone through?
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2024 at 9:06pm
I’d plan on going through the pump at least..
Sounds like something in the pump.
Make sure you time it before you remove the pump…
1955 AC WD45 diesel with D262 repower, 1949 AC WD45
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2024 at 12:06am
pumps bad'
This page was generated in 0.069 seconds.
