190 XT 3pt
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Topic: 190 XT 3pt
    Posted: 30 Jun 2024 at 6:32am
Local guy has a'190 XT in need of a 3pt. Has a 200 parts tractor. We are wondering if the hitch off the 200 will fit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2024 at 6:34am
The hitch itself would hang on the rear of the tractor, but the lift cylinders would have no place to connect up as the 200 is way different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2024 at 8:51pm
Thanks Dr. I'll let him know.
Randy Magnum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy Magnum Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2024 at 10:27am
If you swapped the rear axle housings, would it work? And lift way more than a 190?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2024 at 10:47am
YES. But, that's a lot of work, whereas if you just find a 3pt from a D-19 or any 190/190XT it is a bolt on deal.
