??? Wide Swinging Draw Bar ??? |
Unit3
Topic: ??? Wide Swinging Draw Bar ???Posted: 28 Jun 2024 at 3:53pm |
Does anyone know if a wide swing draw bar can be put on a tractor that has a three-point hitch? I am wondering if one could be put on my 8050 and still leave the two-point arms in position. I know I can’t use the three-point I just wanna know, if there’s anything that would get in the way drawbar brackets .
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 28 Jun 2024 at 9:23pm |
On an 8000? No, you can't have both.
Unit3
Posted: 28 Jun 2024 at 9:41pm |
Well, I know you would have to leave the three-point up. I know you couldn’t use it, but is there anything underneath where the white swing would bolt to that three-point? Parts would interfere with?
DrAllis
Posted: 28 Jun 2024 at 10:49pm |
I think if you dropped off the entire bail assembly and removed the rub blocks from each draft arm and left the draft arms fully UP, it might work.
Unit3
Posted: 29 Jun 2024 at 4:06pm |
That’s kind of what I was thinking. The thought is to put a hydraulic cylinder on the drawbar. That way I could push/pull the Planter hitch off to each side, depending if I’m going north or south through the field.
My landlord wants to cover crops and I’m trying to figure out a way to get my soybean row close to last year‘s Corn stock row. I make 3 Complete passes around the field and then I start working my way from one side to the other. |
DrAllis
Posted: 29 Jun 2024 at 5:04pm |
If the draft arms are in the way, they drop off very easy compared to older A-C models. I can't imagine the torsion bar would be in the way.
