HD6 Clutch Needed
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: HD6 Clutch Needed
    Posted: 27 Jun 2024 at 8:40am
I have a friend looking for the main engine clutch on an HD6, would anyone have a lead on where to get one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2024 at 1:03pm
Wet or dry unit , believe General Gear would be one supplier .
Also a good truck and transmission shop supplier would be another place to look once you have unit out .
 On many units the clutch is adjustable also and accessed through plate on bellhousing .
I replaced the dry clutch on my HD5 with a ceramic button clutch years back and seldom need any adjustments or service.
 Another unit I had I replaced the disc with one from a IH parts truck I bought
AC used many stock parts from major suppliers rather than having special or priority built parts used for only AC .
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2024 at 8:41am
Thanks for the tips, yes it’s a dry clutch. I’ll let him know what you said and hopefully he’ll get back to going!
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2024 at 2:32pm
I am still have some used cluch parts for HD6
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2024 at 7:16am
i have a 6g in central ks parting out.  needing everything or specific parts?  I would need to take it out and have a look as its sloppy engagement.  could be out of adjustment or just worn out.
