AC 5030
fhelliott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fhelliott Quote  Post ReplyReply Direct Link To This Post Topic: AC 5030
    Posted: 25 Jun 2024 at 10:48pm
J have an AC5030 with a failed PTO One Way Clutch.  Does anyone know where a new PTO one way clutch could be obtained?
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2024 at 12:29pm
Part number 72098526.   Try Agco dealer or maybe Sandy Lake?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2024 at 4:08pm
It appears the clutch unit was $800. about 10 years ago.... Useage is LOW and i dont see anyone that stocks / sells one today.... Possibly an AC dealer still has one setting on the shelf somewhere ?    Massey and Hinmomoto (sp)  used the same clutch..
Saw one post where i guy was going to "LOCK UP" that clutch and direct drive the PTO... then use a "GENERIC"  over running clutch behind the tractor... no comment if that worked or was even possible..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2024 at 4:13pm
GENERIC  slip clutch...
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2024 at 11:21pm
If you can find out who actually made the clutch, you might be able to replace the innards. Chances are it’s a Ringspann, or the Japanese equivalent. Siam was another overrunning clutch source.
https://www.ringspann.com/en/products/freewheels
