OT Oil Life Index |
Post Reply ![]() |
Page 12> |
Author | |||
Phil N ![]() Bronze Level ![]() ![]() Joined: 14 Sep 2009 Location: Vermont Points: 6 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Nov 2010 at 1:06pm |
I recently purchased an '06 Chevy Trail Blazer with On Star. I changed the oil when I got it home and reset Oil Life Index back to 100% and it was confirmed on my account on my computer. After 3000 miles of driving I checked my On Star account on my computer and it said my Oil Life Index was still at 94% and my next oil change was due at 49,500 miles. If I let it go that far, there will be 13,500 miles on the oil. This seems excessive to me. I realize I can change the oil as often as I want. I also realize GM wants repeat customers after wearing out your vehicle. I have always been a maintenance nut. I was thinking of changing at about 6 or 7000 miles. It has the 4.2 L inline 6 cylinder engine and it takes 7 quarts of oil with the filter. I use Full synthetic oil and change the filter every time myself. The truck is driven in Central Vermont and does not get driven on short trips. With the price of oil these days, it makes you wonder if you might be going overboard. What do you guys think? Thanks in advance for your input.
Sponsored Links | |||
Goose ![]() Orange Level ![]() ![]() Joined: 07 Oct 2009 Location: Melrose, Wis Points: 2471 |
I know they increased the mileage considerably between oil changes. At work we got a new Dodge Avenger. The boss told me to take it to the shop at 3,000 miles, so I did. The mechanics sent me back without the oil change. According to the manufacturer, oil changes occur every 7,000 or 9,000 miles (I can't remember which right now). I think that is excessive miles, especially on a new vehicle.
wf32 ![]() Silver Level ![]() Joined: 13 Sep 2009 Location: Brownsville MN Points: 455 |
The new oil life indexs base off engine rpm and run time and other varibles to driving.
Most we see at work go 10000 miles at least before it shows you need oil change.
Know its your vehicle how long do you want it to last.
Its cheaper to change oil than engines.
just my two cents
Phil
Brian Jasper co. Ia ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
As a Ford and GM dealer tech, I will also agree with the do you want it to last and be trouble free? The exhaust cam has a phaser on it that is controlled by oil pressure. Dirty neglected oil is the number 1 cause of the cam phaser and solenoid valve failing. The oil life monitor is based on actual driving. All highway miles and it will take longer to signal an oil change. Lots of short trips will cut it back. Take my advice and change at 3k for ordinary oil, no more than 5k for semi synthetic.
smuggler ![]() Silver Level ![]() Joined: 23 Dec 2009 Location: western ny Points: 325 |
On my 99 silverado 6.0 liter. I think the thing works fairly well. If im pulling the gooseneck alot it goes of around 3000mi if not its been upto 6000 b4 it has went off and said change the oil. Rite now the silverado has alittle over 198,000 miles never touched the engine and its still strong
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5617 |
My 2008 Silverado 2500HD DuraMax has 6,000 km (3600mile ) on it and showing 64% oil life remaining.
That statistic means I could go approx. another 12,000 km ( 7,200 miles ) before I would need an oil and filter change. ( Total of 18,000 km / 10,800 miles )
BUT it is going in friday for oil and filter change.
I have gone as far as 9,000 km ( 5,400 mile ) but not any further.
Clean oil is the life of an engine.
Gary
firebrick43 ![]() Orange Level ![]() Joined: 10 Dec 2009 Location: Warren County Points: 592 |
The oil companies have perpetuated the 3000 mile myth for so long that many belive it. In modern engines, with modern oil there is not reason to change at 3000 miles. Don't believe me, send a sample into the lab for a test. Air filter/intake systems have come a long way and seal/filter much better than the days with the filters bolted onto of the carb. Fuel injection systems prevent fuel dilution due to sticking needle/seat or rich running carbs.
On the other hand, the manufactures have been pressed to extend their oil change intervals for "environmental" reasons. The general population might be well served by these recommendations but certain groups should change theirs somewhere in between. Most on here live near or on farms which means more dust, and use their vehicle for work(the general population doesn't) Aftermarket filters such as the K&N should change the oil at 3000 miles as you are sucking more dirt into the intake. |
john(MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: SE MI Points: 9262 |
6000 to 7500 is what they should be changed at, and it should probably show that in the owners manual! I have gone to 5000 on all of mine, the math is easier! :)
Jordan(OH) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Celina, OH Points: 1547 |
Our hoof trimmer changes his 7.3 Powerstroke every 10-12k with synthetic. Going on 300,000 now.
Theres no myth about it. Why do you change oil? Is it worn out? No, it's DIRTY. You change it to get rid of the contaminates. Those contaminates are what causes wear. Those contaminates are what build up and plug the screens in things like cam phasers. |
Charlie175 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6358 |
3 to 5,000 miles for me depending on the vehicle.
Our Denali has the monitor and it varies but averages around 5,000 miles till the oil is at 20% and I change it. I don't go less than 20%, and since my wife can't remember to tell me, the email onstar sends out is a engine saver! |
Charlie
'48 B, '51 CA, '56 WD45 '61 D17, '63 D12, '65 D10 , '68 One-Ninety XTD |
bluebanshee ![]() Silver Level ![]() Joined: 19 Jun 2010 Points: 65 |
I also have a TrailBlazer. Quite a few people on the trailvoy forums change their oil at 6-8k. I changed mine 4,000. At 3,000 it still looked like I just changed the oil it was that clean. These motors aren't know for problems, transmissions and cooling fan... I doubt you could find any evidence of an oil related failure (unless its an extreme case, ie. 40k on an oil change). The oil filter location on these motors is one of the worst I've ever worked on, if it is overtightened and your not using an oil filter wrench.
It is probably just as important to look up what oil filters are the best. If you like working on them, you can check and clean your throttle body. Their are tutorials on the trailvoy site. If you are looking for a little off the line power and firmer shifts you can send out the PCM to be tuned. No more lazy shifting that they are known for. Edited by bluebanshee - 03 Nov 2010 at 12:42pm |
Good ![]() Orange Level ![]() ![]() Joined: 05 Apr 2010 Location: Logansport IN Points: 453 |
My 05 Merc. has that also but in percentages it goes off between 3 and 4 thousand. I wouldn't let it go any further than 5 thousand because like motorheads say I want the engine to last awhile. Funny thing about the car is it uses 5W20 but I have 111,000 on it and it doesn't use a drop inbetween changes.
B212,716,two 314H's,WC,WD,D19,190XT
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 23531 |
My friend just went 1,000,000 Km ( 600,000 miles) in his ramcharger(86 or 87),changes oil every 10,000Km(6,000 miles).Used for snowplowing all winter,hauls 4000# trailer every weekend,so it is used and not pretty.
I remember Tom McHail(sp) ,wrote for Mechanix Illustratd in the 50s,60,70s... said changing the FILETER is the important thing, oil never wears out.
I know engines have come a long way,oil too...but I change every 5,000Km as it's easy to remember and only have 100,000Km on my 97 F-150.
Gary in da UP ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: EUP of Mi. Points: 1885 |
Send a sample of your drained oil to a lab for analysis. With a synthetic and 7 qt. of capacity , I would change at 7500 or 8 thou, unless the monitor recommended sooner.
Rick of HopeIN ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Hope, Indiana Points: 1324 |
on my 18000 mile/year minivan I go 7500 miles, otherwise I go for the easy math and do 5000 miles. Years back I always used 6000 miles, I think because it was the number in my old Ford manuals for many years...
Did you read my reply Brian? I mentioned nothing about wearing out. I talked about fuel dilution and silicon contamination(dirt). (Multigrade Dino oil does oxidize but not any where near 3000miles) These things just don't happen in modern fuel injected vehicles in good condition at 3000 miles. Yes they were applicable to older carburettor equipped vehicles, but since we are talking oil life index equipped vehicle, 3000 mile oil changes are unnecessary. I have never seen an oil sample come back recommending chance at 3000 miles, except for two reasons, one was a coolant leak and 2 was a vehicle with a tear in the air intake hose.
Can you explain to me how regular oil gets "dirtier" quicker that semi synthetic? The type of oil has nothing to do with particulate contamination, nor fuel dilution, nor moisture. Even modern dino oils won't begin to see appreciative oxidation at 5000 miles. Contamination is a result of the efficentcy of the air filters(which is upwards of 96 percent with modern rectangular pleated filters) the crankcase ventilation system, and malfunctioning equipment. So exactly why can you go 5000 miles on semi synthetic but not standard oil???? |
So how many miles could a guy go on a LP engine in a truck since there is very little contamination from the fuel.I don't know enough about oil but I can't see oil not breaking down from use and age.You would think we would have been recycling it with some sort of super filter kit we could have in our shops and never need to buy new.
Well Good, there are many variables to consider. The hotter the engine runs(which propane engines do run a little hotter) the faster the oil oxidizes. Also the enviroment that it runs in and how well the air filter(intake is the largest source of dirt) is a big factor.
The engines I work on go in some of the largest mining equipment in the world. These are 3000hp+ diesel engines with 150 gallons+ of oil depending on model/application. These mines operate 24/7 364 days a year and never even shut down except for major maintenance. They don't even shut down for fuel/driver changes. When refueling, the service truck hooks up an oil polisher that circulates oil from the truck and filters through 2 micron filters and through high quality cotton bypass filters to take carbon black out and other sub micron particles. Some mines use straight 30W dino oil. Multigrade oils break down faster but provide much better start up protection, but since these machines are never shutting down, that is not an issue. If using dino oil they will at intervals pump a few gallons of oil into the fuel tank after its polished and make up a few gallons with new to refill. Pretty much replacing all the oil once a year. The mines running synthetics never change oil as they don't break down. The important part of all this is the oil sampling. Done right the can tell you with pretty good accuracy what is happening in an engine and tell you well in advance on impending failure. Some of these engines have special double filter units that you can shut down the main filters while the engine is running and replace them without ever shutting down. This is a very common item on the engines going into ships as well. Ship engines have very long oil life due to the low dirt content in the air, consistent load, and consistent temps. Some ships also use the polishers as dealing with oil changes can be a very big problem on boats On a personal note. I have a truck that I used to have a set of bypass cotton filters on it and changed the oil every 25000 miles but check the oil at 12500 by oil sample analysis. It has 280000 miles and never been opened up. I did eventually take them off because the company that made them (Amsoil) raised their prices so high that it was not cost effective especially now that I don't drive it very much(its the farm beater truck now) especially for 6 quart capacity. Now on a large truck with several gallons of oil capacity, it would be worth it monetarily. Setting/short operation times or infrequent operation promotes water condensation and you need to change the oil even if it hasn't run that many hours/miles just to remove the water in the oil and prevent acids from forming. Edited by firebrick43 - 05 Nov 2010 at 12:55pm |
Stan IL&TN ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
With too many cars/trucks to keep up with I find it easier to just change the oil twice a year and do them all at the same time while I have everything out and not watch the miles at all. Running full synthetic for about 10 years now.
1957 WD45 dad's first AC
1968 one-seventy 1956 F40 Ferguson |
You guys about have me sold an synthetic oil.Do the old nonfiltered big briggs and stratton like the synthetic?
No, they should use straight 30W(unless cold out) and change the oil frequently. Synthetic is not hard on them, just not worth the cost. The lack of oil filtration/poor air filtration requires changing the oil often on these motors. Depending on the model, fuel dilution is a huge killer on these small engines as often the carbs leak. The new briggs vanguards are going as far as to have the engine cut off switch and fuel shut off switch on the same lever as they found that many industrial/commercial/rental engines have significant less life do to the fact that few shut the fuel off at every shut down and the bouncing/vibration of transporting the engine down the road allow even a good needle/seat to leak fuel into the crankcase and wash down the cylinder walls good. Some of the large Vanguards, kawsaki, command pro kohlers, and honda with oil filters and donaldson canister style air filters they do recommend synthetics as it resist oxidation better due to higher temps that air cooled engines run at and the longer durations that the improved filtration allows. Some of these engines are now EFI as well. Honda just came out with a 13 hp efi engine so watch out, even the smaller engines are going to be fuel injected soon for emissions.
Edited by firebrick43 - 05 Nov 2010 at 12:50pm |
I work with this stuff daily, but don't listen to me. I'm just the guy with the bad news on what it takes to fix your engine after you neglected it...
tomdavison ![]() Bronze Level ![]() ![]() Joined: 03 May 2010 Location: Canton, PA Points: 49 |
In 1974 I worked for a trucking comany. Everupme was looking for advice on oil changes as the cost of the oril change had dramaticaly increased due to the oil crisis.
I saw article in a trucking publication about a study peroformed I believe by Lockheed Aircraft in California. They took trucks in their own fleet and set up different approches to oil changes. They took some and revmoved all filters, others they cut the filters in half, some they run long mileage and some short. Some the did not change the oil at all. At the end of the study, they tore down all engines and instpected them for wear and damage. There conclusiion, none of them seemed to show much difference in wear. I don't know what size trucks these were.
I did, and once again if this was 1985 I might agree with you on 3000 mile oil changes, but oil and engines has gotten a lot better. SM and CF-4 oils have excellent additive packages now, that don't crap out at 3000 miles. Semi synthetics don't do any better in this area, they are only more consitant molecule size and slightly better lubricating properties(slicker/more load carrying capacity) for increased fuel economy and decreased wear at start/warm up. Have you been in an oil lab? Seen oil testing? Seen Oil test engines? I have to walk but 150 feet each day to. I agree that 10-12 thousand miles in light vehicles with low capacity oil pans with out extra filtration is to much but there is not reason that 5000-7000 miles can not be used today in average driving, using your head to adjust to sever conditions to adjust your interval. Edited by firebrick43 - 06 Nov 2010 at 10:35am |
omahagreg ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Omaha, Nebraska Points: 2806 |
When I had my FedEx Home Delivery truck, I had to go to Freightliner (they had the warranty) to get an explanation of my owners manual. I had to have a maintenance plan on file with FedEx, and they would not believe how many miles they were allowing between changes. I was driving as many as 350 miles per day, 5 days a week, and at the 5000 miles common to diesel engines I would have been changing it OFTEN. Freightliner said I could go up to 10,000 miles with that kind of service.
Greg Kroeker
1950 WD with wide front and Freeman trip loader |
Yes greg, but how many quarts/gallons did that engine hold. The engines I build at work may have 110 gallons which have 250 hour oil change interval or may be set up with 250 gallons and better filtration with a 1000 hour interval or something in between. The applications were different on all these engines but same basic block/crank/head.
This is why in my post I try to be careful and point out that we are talking Light vehicles such as a car/pickup and not a larger vehicle. If you where talking about a sprinter van however, I do think that was a little much. |
I was just showing how much everyone has a different opinion on oil change interval-including FedEx! I never changed the oil myself, as it would be hard to document properly, but I think it was at least 20 quarts in a 4 cylinder, turbo charged, and intercooled engine. As you can see, it was not a sprinter type.
Greg Kroeker
Tricky Dickie ![]() Silver Level ![]() Joined: 05 Nov 2009 Location: North Yorkshire Points: 186 |
Modern oils in a modern engine will go at least 20000 miles in normal use. The technology of lubricants, engines and oil filters has changes out of all recognition since the days of 3000 mile oil changes! I was in the oil business for many years and one of our companies ran a large fleet of trucks which worked 24/7 delivering fuel oil to power stations - we used long life lube oil of our own manufactire in them and changed it every 50,000 miles (yes, that's 50,000 miles!) We took one truck to 1 and a half million miles this way as a trial and as an advert for our lube oil and when we finally stripped the engine, the bearings would have gone back in quite safely and the bores had hardly any wear. I sold that truck to an owner driver who did some work for one of our companies and he ran it the same way for another 5 years. Relax and don't waste your money on unneccessary oil changes.
Edited by Tricky Dickie - 06 Nov 2010 at 1:29pm |
Post Reply ![]() |
Page 12> |
