Snap on drive-not quite 3/4 "
Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Quote  Post ReplyReply Direct Link To This Post Topic: Snap on drive-not quite 3/4 "
    Posted: 24 Jun 2024 at 6:48pm
I thought I might get a better chance for a reply on this discussion section than others. Hope its okay to ask here.
I picked up some some large snap-on sockets (largest is 2 1/4 inches) at an auction. Thought they were 3/4" drive but they're not. They are slightly smaller (a 3/4 " ratchet won't fit) The info ring on the socket reads: Snap-on 2 1/4 LDH-722 USA
Anyone with an explanation?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2024 at 6:57pm
you better check for a burr or twist in your ratchet... try a 3/4 inch extension.. should fit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2024 at 7:04pm
I had a couple sockets that someone used on a PRESS to push bearings into position... The FACE of the square drive was mushroomed about .020 inch and would not fit a ratchet... but that was only a COUPLE sockets in the bunch.. cleaned them up with a burr grinder.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2024 at 7:16pm
Check for damage as already said, a 3 sided file works to clean the corners if they're pushed in. Yes, I'm 1 of them mentioned that's used sockets to press things into place.
 There were some 5/8" drive socket sets years ago if they're visibly smaller than 3/4" but larger than 1/2".  But I haven't seen any in years.
RLBPA1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RLBPA1 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2024 at 7:28pm
Looks like back in the day snapon made some large sockets in 5/8 drive
Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2024 at 7:31pm
You're all correct. Just checked and it's a function of burring. Never seen that before on mine. I guess because I treat mine with some respect. LoL
Edited by Dale - 24 Jun 2024 at 7:32pm
