H3 crankshaft pulley
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Topic: H3 crankshaft pulley
    Posted: 23 Jun 2024 at 3:49pm
Can anyone tell me the part number for the front crankshaft pulley of an early H3 dozer? I can't find the H3 in the Agco parts lookup. Most parts I've been using D14/D15 manuals, but the part numbers for the front pulley on the 14/15 seem to be different, so I would like to get the right one. Mine turned up missing since I took this apart last year. I spent a couple hours looking for it, and I know I will find it as soon as the replacement gets installed, but thats how it goes. Thanks in advance for the help.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2024 at 5:41am
Per the D-14 Parts Catalog, early D-14 used front Pulley 229698.
At Engine Serial 11562 it changed to 230712.
The change was 4 threaded holes were added to acommodate the bolt on coupling for the front mounted hydraulic pump required for the 414 hydraulic loader.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2024 at 6:50am
Also the early D15 tractors had a wide fan belt and later tractors had a narrow belt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2024 at 7:15am
Thanks, but like I said, I have part numbers for the tractors.. I'm looking for the correct part number for the H3
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2024 at 8:16am
Managed to find my Allis Dealer Parts Catalog for H-3 and HD-3.
On P-8 Crankshaft Pulley for Gas is #233396
Adapter that mounts to Pulley with 4 bolts for a Hand Crank is #233401.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2024 at 9:21am
I had to use AGCO parts books to verify, but the D-15 gas farm tractor engine is 70235043 for the pulley and 70233432 for the narrow fan belt. No wide fan belt like the D-14 was ever used on a D-15.
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2024 at 9:48am
Thanks gary, that's exactly what I needed. I ordered a new one from steiner. Unfortunately for some reason the 3/8" belt pulley is almost $40 more than the thicker belt pulley... this project is wildly over budget as is, so might as well just keep going!
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2024 at 11:04am
I thought over budget is the only way it would work
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2024 at 1:04pm
"This won't cost that much." is the lie we tell ourselves....It's not a budget problem per say. It's that we aren't realistic when making a budget.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2024 at 2:09pm
There is NO  budget for something you want !!!! That you already got into.
Edited by Fred in Pa - 24 Jun 2024 at 2:09pm
nonetheless ,still dead.
