D-14 pilot bushing replacement? |
Post Reply ![]() |
rasman57 ![]() Silver Level ![]() ![]() Joined: 12 Sep 2009 Location: Illinois Points: 402 |
![]() ![]() ![]() ![]() ![]() Posted: 23 Jun 2024 at 9:25am |
D-14 Doing a clutch replacement....AGCO doesn't have the pilot bushing... are they available or been replaced with a modern bearing/bushing? Appreciate any experience with this as mine is galled and beat up.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21779 |
possible ?...https://stores.djstractorparts.com/clutch-pilot-bushing-allis-chalmers-d10-d12-d14-70228188/ googled 'allis-chalmers d-14 pilot bushing'
Thanks!
No joy it looks like only the very early D-14... not my 60. Wonder why? |
Ed (Ont) ![]() Orange Level ![]() ![]() Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1234 |
Wonder what the dimensions are? Any chance of automotive interchange? May be worth a look.
Hmm....Your D-14 must be a true 12 volt tractor ( generator has smooth shell, no 'brush band cover ) ? |
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8216 |
Are you talking bushing 228188. It’s same part number in parts book for both serial number breaks.
Fred in Pa ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9144 |
I will check when I get in shop in the morning ,I did have some extra new ones
I know the ring gear on early D14's are different but the pilot bushing serial number break info surprises me. If the vendors info is correct. AGCO says not available so must have been very limited . Dimensions would confirm. Once I get it out.
Edited by rasman57 - 23 Jun 2024 at 10:04pm |
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5230 |
I checked an Allis Parts Catalog for D-14 printed in Oct., 1961 ( after the end of D-14 assembly) and it does not show any break in Serial number for the Pilot Bushing. Only one P/N 228188. The 149 Power Unit however uses a different number, 226859, a bearing. G ............................................................. There is a definite reason why there is a Serial Number Break for D-10 and D-12. The posted Serial Numbers are the start of the Series II. The Ser.II had Live Hydraulic and Live PTO. A solid Shaft was splined in to the Flywheel in place of the Pilot Bushing. This shaft provided power to the PTO and rear mounted external Hydraulic Pump. Edited by Gary - 24 Jun 2024 at 8:53am |
Thanks for the research. Appreciate the info!
I am out of them . DJ will take care of you.
Post Reply ![]() |
