HONDA - Class 8 truck fuel cell
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Topic: HONDA - Class 8 truck fuel cell
    Posted: 22 Jun 2024 at 1:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2024 at 1:13pm
WHERE do they propose to get the HYDROGEN ??   YEP.. thats what i want... a truck rolling down the highway at 80 MPH with a 10,000 PSI tank fill full of HYDROGEN !! ..... Can you say HYDROGEN BOMB ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2024 at 9:42pm
Seems Iceland has switched much of public transportation and public owned vehicles over to Hydrogen as main fuel source , so it's being used on daily basis .
  Not much said about electric charging and lithium battery fires , or the weight and range from vehicles so equipped .
  The full EV fiasco reminds me of the  CFL lightbulb idea , YOU must change over all your bulbs to CFL to save the planet . EXCEPT call a Has Mat team if you break one as they contain Mercury and other harmful thigs . They don't work in cold , and the life is rated at 3 hours or less use per day .
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2024 at 6:10am
Hydrogen ? The Earth has a nearly ENDLESS supply !!
Simply put two electrodes into a pail of water, and put power to the electrodes.
one make Oxygen, the other hydrogen. EASY
OK, to POWER the system, connect  a few windmills and solar panels
There you go...... totally FREE energy !!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2024 at 6:14am
hmm.. glanced at the 'specs'....
WHY does a 'hydrogen powered ' truck need a 120KW high voltage battery ?
Wonder how much heavier the truck weighs ?
What's it cost to tow it when the fuel runs out ?
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2024 at 7:56am
YEP... put $2. of POWER IN and get $1. of Hydrogen out... NOTHING is "FREE"..
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2024 at 9:08am
Screw the green energy fad.
Stick with reliable traditional fuel.
Trying to reinvent the wheel is REDICULOUS!
