3 Point Forks Usefulness? |
dfwallis
Topic: 3 Point Forks Usefulness?Posted: 21 Jun 2024 at 9:37am |
Are 3 point forks really that useful. It seems like the raise distance is so tiny that you can't do much with it.
1952 CA13092
plummerscarin
Posted: 21 Jun 2024 at 12:57pm |
All depends on what you determine usefulness. Me, I use them to pick round bales from the field and move to storage location. All ground level. Can even load some bale trailers with it.
Once had a telescoping 3pt forklift. Kinda clunky but had more height. For me, the real drawback is it’s behind you and craning your neck to see what’s going on is the challenge. |
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90846 |
Posted: 21 Jun 2024 at 1:36pm |
I have a set of fork truck type forks on a 3 point attachment. Use on a "B" tractor a few times a year.. YEA... about all you can do is pickup a pallet and move from the barn to the garage... move an oil barrey around ... picku a mower deck or plow to move.... Not to lift up and put parts in the pickup or shelf..
dfwallis
Posted: 21 Jun 2024 at 1:38pm |
Yup. I see moving things around from one ground position to another. But I often need to load and unload a flatbed or pickup, usually pallets.
1952 CA13092
steve(ill)
Posted: 21 Jun 2024 at 1:55pm |
i had considered building a 3 points set of forks that also could "lift an extra 2 feet" by using a cylinder / hand pump... or a boat winch...like an actual fork truck... just for that reason... but i really dont use it that much.
Does not have to be really BEFFY as your only talking about lifting less than 500 pounds. Edited by steve(ill) - 21 Jun 2024 at 1:56pm |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25270 |
Posted: 21 Jun 2024 at 1:59pm |
Used them a LOT to move 'skids of stuff', here,there, everywhere and then back to there.... Also GREAT for lift huge logs that nobody else can lift !!
bigal121892
Posted: 21 Jun 2024 at 4:51pm |
Lot of people around here have these:
dfwallis
Posted: 21 Jun 2024 at 5:05pm |
That's what I was looking for! But no cat 1/lightish duty that I see.
1952 CA13092
steve(ill)
Posted: 21 Jun 2024 at 5:08pm |
that would work great on a 10,000 pound tractor... but the B, C, CA would not even lift the 3 point, let alone any LOAD !..... Thats a 4,000 pound lift... your looking for something in the 5-700 pound range !
ac fleet
Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Posted: 21 Jun 2024 at 5:15pm |
useless on the back of a tractor. GOTTA have them on a skidder then you have something!
dfwallis
Posted: 21 Jun 2024 at 5:26pm |
:) but then you gotta have a tractor AND a skid. If you only need something once in a while, make the tractor do as much as it can.
1952 CA13092
BillinAlberta
Joined: 12 Sep 2009 Location: Saskatchewan Points: 364 |
Posted: 21 Jun 2024 at 5:46pm |
Has anyone tried a scissor lift?It fits between the 3 point and the bale fork.Supposed to double or more the lift height.Hi-lift bale spear is 1 on You tube.
Edited by BillinAlberta - 21 Jun 2024 at 5:52pm |
KJCHRIS
Posted: 21 Jun 2024 at 7:22pm |
I've a set of the Gnuse forks as in Bigal's post.
I think mine are the 9' or 10' model.
I used it to stack 1300 to 1500# round bales 2 high, the AC180 & 185 handle pallets fine just don't pop the clutch, should put the suitcase weights on.! We've used it to set pallets from semi flatbed trailers into bldgs where they want them at other farms. |
