Pulling WD sleeves |
Post Reply ![]() |
Gary (sw Wis.) ![]() Silver Level Access ![]() Joined: 12 Sep 2009 Location: S.W. Wis. Points: 203 |
![]() ![]() ![]() ![]() ![]() Posted: 20 Jun 2024 at 4:02pm |
I am not having any luck pulling a leaky sleeve on my WD. I made a disc (washer) for the bottom and put a 3/4" thread rod up through it for a puller. Then hammer on it with a piece of wood. I cannot get it to move. Any advice or tricks would be appreciated. Or maybe I just need to work at it harder.
![]() Also any advice on putting them bad in (providing I get them out) would be helpful.
190XT - D17 - D14 - WD45 w/loader - WD - (2)B110 - 616H - 610 - B-208 - WD with 190 Mounted Corn Picker - All Crop 60
Macon Rounds ![]() Orange Level ![]() ![]() Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2106 |
Put a bead of weld or two up the inside of the sleeve.
And try again. |
Walker ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: oh Points: 8170 |
Make very sure that what you are pulling against isn't the other end of the sleeve. Stranger things have happened.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 78848 |
when you get it out, wire brush everything clean, then do it again... The sleeve should DROP into the hole easy, without the o-rings installed.. That is the TESTS prior to installing the sleeve WITH o-rings... If it wont drop in, its not clean enough... Some need an emory flapper wheel to get the crud off and "polish".... a little lube is used on the o-ring during reinstall.
plummerscarin ![]() Orange Level Access ![]() Joined: 22 Jun 2015 Location: ia Points: 3258 |
Let's see if I understand you. A disc cut to fit the outside diameter of the sleeve. ¾" threaded rod long enough to pass through the disc and sleeve to the top side. A block on each side of sleeve on the top side and the rod passes through a plate resting on the blocks to create a bridge. Then tightening the nut on the threaded rod to draw the sleeve out?
wjohn ![]() Orange Level ![]() ![]() Joined: 19 Jan 2010 Location: KS Points: 1838 |
I got one of these. They are cheap, look cheap with poor paint finish, maching etc., and certainly aren't made in the USA but it easily did the job on my WD block. If nothing else works it would be an option. |
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3379 |
should not have to weld out a wet sleave it will only pull hard for a half inch just make sure your rig is bridged across the block and it is not on top off the sleave you are pulling
Thanks guys, I would rather not weld on it. I am wide enough to not be pulling against the sleeve. Steve thanks for the install advise and the puller I made is very much like your picture.
plummerscarin, I would say you spot on what I'm trying to do. I'll get back at it in a day or two see how it goes.
On a 170 I have the sleeves were very hard to pull. I added a slide hammer to the all thread. Tighten the nut, bang the hammer, tighten the nut, bang the hammer.... You get the idea.
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 4462 |
I hope you have it on an engine stand, so you can turn the engine upside down. If you don't, it's well worth the time it takes to remove the engine. I've had them just about fall out and I've worked on for hours to get some out. As Steve said, there is no such thing as too clean when reinstalling the new sleeve. Make sure the counterbore in the top of the block is completely clean, so the sleeve has the proper standout. Good luck!
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4505 |
I've seen some engines that had so much crud packed around the sleeve in the water jacket that breaking them was the only way to remove them. Generally with wet sleeves; with the engine upside down and supported off the the floor, using a good block of hard wood and a few whacks from a heavy hammer, they come right loose.
If you can't make it GO... make it SHINY |
orangereborn ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: NW WI Points: 1415 |
sparky ![]() Orange Level Access ![]() ![]() Joined: 13 May 2011 Location: So. Indiana Points: 1479 |
X’s 3
Lon(MN) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Elk River,MN Points: 1928 |
X's 4 but I use square tubing as a punch.
http://lonsallischalmers.com
Good news. I got them all out in one piece. Extra lube on everything, a little extra elbow grease and a lot of sweat got the job done. Thanks agin guys.
Great news for me my WD is back together and running. I bought the service manual and parts I needed from DJS Tractor Parts, all fit perfect and arrive promptly. I had never been that deep into and engine so it felt real good when it started and sounded good.
Thanks to one and all that responded with advise both in this post and several of the old posts on the subject that I read. It was all very helpful. What a great bunch of people we have on this board. God bless you all!!!
WOW... that was quick !! ... Did you hone the old liners and put in new rings or all new STUFF ?
I would say I repaired it. I certainly did not rebuild it. Its farm fresh and I'm the 2nd owner.
It was running great, starting in the winter still running it on 6 volts. In 20 plus years of owning this tractor I had the generator rebuilt 5 or 6 years ago that's it. So when it started getting coolant in the oil I dug into it and found out the #2 cylinder sleeve was leaking, pulled all 4 sleeve cleaned them put new o-rings in and put it back together. New gaskets, old parts. Couple hundred dollars and lot of hours labor and I hope to get another 20 plus years out of it. Some may say I'm crazy since it was apart but I worked in Maintenance for 40 years and learn don't look for trouble were there isn't any.
i normally hone and put in new rings.. but YES, i have done several "overhauls" using the original pistons and liners and getting new gaskets.. !
![]() I worked in Maintenance for 40 years and learn don't look for trouble were there isn't any.... the story of MY LIFE.. ![]() Edited by steve(ill) - 27 Jun 2024 at 6:25pm |
Post Reply ![]() |
