200 internal leak, quick fixes?
INAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote INAllis Quote  Post ReplyReply Direct Link To This Post Topic: 200 internal leak, quick fixes?
    Posted: 19 Jun 2024 at 3:11pm
1973 200, losing hydraulic fluid from left to right, hydraulic to diff? Realize it will require a split, anything I can do to get me through a few months until I can properly repair? I was thinking maybe a siphon hose??? Idk. TIA
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2024 at 3:30pm
I dont know how to overcome it externally but my daddy put a spicot on the differntiak drain and kept a gallon jug and a funnel and transfer fliud for three years until he traded it for a 7040
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2024 at 4:46pm
You can plumb them together to equalize them. Fill to the higher level of the 2 dipsticks. Probably thru the drain plugs. Someone with experience hopefully will answer with more details.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2024 at 9:30pm
It has been talked about in other posts if you do a search I don't know if anything about it has been put in the knowledge section.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2024 at 11:08pm
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2024 at 11:18pm
Temporary fix has been to connect the Hydr & Tran/Diff compartment by going from front to rear drain plugs with a hose.
 I worked on clutch in tractor that had been connected that way to get thru planting.
 They'd removed 1/2" npt plug in torque tube & installed a 90 and reducing bushing 1/2 to 1/4", drilled & tapped tran plug to 1/4" npt, installed brass 1/4" 90 and ran a 1/4" hose between them.
 F Y I; A word of caution the Tran plug is directly above the drawbar, and there's not much clearance between drawbar and the 90.
DPKII View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DPKII Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2024 at 9:21am
I recently did based on the pictures in the post above after finding oil dripping everywhere on the drawbar after about an hours use.  I originally thought it was coming from the rockshaft as it was dripping from there but now I am thinking it may be coming from the lift cylinders.  I installed the catch can to eliminate any metal shavings finding there way from transmission to hyro reservoir.  I have a strong magnet in the bottom of the catch can as well. Wanted it semi-permanent as I will not be able to try spitting the tractor any time soon. Never split anything as large as the 190.
