Barbless Hose Barbs ?
BuckSkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Topic: Barbless Hose Barbs ?
    Posted: 18 Jun 2024 at 3:18am
I have searched and searched and must not be calling them by their proper name.
For fuel lines, I very much prefer those smooth-shanked hose "Barbs" over the more common barbed hose barbs.
Yet, when I try to search for them, I keep getting references to barbed hose barbs.
I know such an animal exists as I have used them for years.
I need a few 3/8" 90° elbows.
I prefer to employ a 90° barb in places where otherwise the hose would want to kink.
What do I call these barbless hose barbs ?
im4racin View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2024 at 5:21am
Hose nipples have just one barb on the end and are more removable
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2024 at 6:26am
they are called “beaded” or “single bead” fittings
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2024 at 10:47am
YES ! THANKS !
I could not think of anything they might be called that a search would understand.
I have my share of the ordinary barbed kind here and there when they were all I had; but, I much prefer the smooth kind.
I have never had one even offer to leak; and, if I ever have reason to pull a hose off, the hose comes off undamaged and ready to clamp again.
As for taking hoses off, after I found out about JIC adapters and swivels, I only ever use them in places where a hose might ever need be removed for whatever reason.
But, on a run of hose where the hose needs make a turn and might tend to want to kink, I like to use a 90° barb of whatever else is warranted.
I have never found such; but, I wish they offered short lengths of bendable tubing with hose barbs on both ends just for such purposes.
Thanks for heading me in the right direction.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2024 at 10:51am
Hydraulic Coupling - Single Bead - 6SB-6RMP90 ...
Use w/ Low Pressure Hose Such as Multi-Purpose or General Purpose Hose. Single Bead Fittings Are Quick Connecting, Field Attachable & Reusable.
Barbed fittings are a simple Slip-in style fitting that works with many different types of Tubing and Hose. Some barbed fittings may only have a single bead ...
Place your order online for Gates Male Pipe with Cone Seat (Single Bead) G37100-0806 and pick it up at your local abcauto for free.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2024 at 4:18am
Yes; those be the animals I was looking for; thanks.
