WD headlight ground
Lingle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lingle Quote  Post ReplyReply Direct Link To This Post Topic: WD headlight ground
    Posted: 17 Jun 2024 at 1:11pm
anyone done something different with the ground for their headlights rather than the light frame tube to the tractor frame?  I am thinking of drilling out the rivet holding the headlight brass grounding strap and then re-rivet with a dedicated grounding wire?  maybe upgrade to LED headlight bucket?  FYI this would be used on both my WD and WD45.
35 and 41 WM crawlers, 49 WD, 53 WD45 wide front, 49 JD A, 52 JD B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lingle Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 1:14pm
so must not have searched very well and I just found this forum post: https://www.allischalmers.com/forum/wd45-headlights-not-working_topic169401.html looks like adding a separate ground to the reflector is the way to go.  anyone upgrade the socket to be a LED?
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 1:44pm
I put a sealed beam in the original mounting but it was only a halogen bulb.
It was a 4.5” round so I’m sure there is a led version.
I found a 1/4” air hose that I put around the outside of the bulb and the inside of the original clamp and it would keep everything tight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lingle Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 2:39pm
Any chance you may have a PN?  also were you able to reuse the outer clamp and did you need the seal?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 6:56pm
I should be easy enough to run a second wire in the mount tube and have the extra ground completely hidden.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 10:15pm
I did what Paul suggested a few years ago on my WD. Grounding is so important on these ole tractors. It will drive you crazy sometimes. I ran a new ground from each light bucket to the frame of the light bar. All hidden in the light tube, cleaned the ground area that the battery grounds to(2nd time) upgraded to 2/0 welding cable and all my issues disappeared. Old metal rusts and the ground doesn't work well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 11:08pm
I use a par 36 sealed beam and yes I kept the original clamp.
I had a high/low beam light in it for awhile with 3 wires running through the original pipe but than just ran the two wires for ground and high beam.
I can try to get a closer picture tomorrow but this is all I have right now.
