CA Starter Locking Stud |
1955CA
Joined: 10 Sep 2018 Location: Ontario, Canada Points: 602 |
Topic: CA Starter Locking StudPosted: 16 Jun 2024 at 5:03pm |
Anyone know where I can get a proper locking stud that holds the starter in on a CA? The one with the tapered or pointed end. The 2nd CA I just bought just has a regular bolt in it.
Starter failed in it, so have to replace it and want to put a proper bolt back in. Also looking for a hand clutch handle if anyone has both they want to sell.
ac fleet
Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Posted: 16 Jun 2024 at 7:01pm |
I turned down a bolt for a neighbors tractor to make the taper on it ---- still working after 5 years for him.
dfwallis
Posted: 16 Jun 2024 at 7:55pm |
1952 CA13092
Lon(MN)
Joined: 11 Sep 2009 Location: Merrill Wi Points: 2048 |
Posted: 17 Jun 2024 at 5:51am |
The bolt had a screwdriver slot. Hard to get them to tighten up. Then folks noticed WC, and WDs had lots of these special Allis bolts with the hex head and used them. They are a special taper. I have a bin full of them.
http://lonsallischalmers.com
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25255 |
Posted: 17 Jun 2024 at 6:32am |
hmm... maybe take it from your 1st CA ???? ![]() OK, I ground a point on a regular bolt for one of my D-14s 10-12 years ago. It was fine. I think the 'trick' is to make the taper(pointy portion) a smaller taper than where it goes in. |
1955CA
Posted: 17 Jun 2024 at 7:46am |
Going to get Steve at B&B to rebuild my starter as soon as I get it shipped to him and he may have a bolt, but if not I'll buy one off you Lon if you want to sell one?
Last resort will be to get my local machine shop to make me a couple. Or just buy a hand crank for CA #2, LOL
sparky
Joined: 13 May 2011 Location: So. Indiana Points: 1834 |
Posted: 17 Jun 2024 at 12:33pm |
That bolt also uses a lock nut.
1955CA
Posted: 17 Jun 2024 at 8:34pm |
Yes, both of mine have a locknut on them. Just the recent purchased CA has a regular bolt.
Lon(MN)
Posted: 18 Jun 2024 at 6:44am |
The bolts are for sale if you need one.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4278 |
Posted: 18 Jun 2024 at 8:28am |
Jeeze, I'll have to look at my CA's and see what they have for starter retention. So far I've never had a starter problem with a 125. Have plenty of the WD style bolts around, somewhere. |
