FOR SALE HUGE RANGE OF FUEL INJECTORS AND PUMPS
Atkinsons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Atkinsons Quote  Post ReplyReply Direct Link To This Post Topic: FOR SALE HUGE RANGE OF FUEL INJECTORS AND PUMPS
    Posted: 12 Jun 2024 at 9:22pm
In Stock Huge Range of Fuel Injectors & Pumps
Worn injectors can reduce engine efficiency, shorten component wear life and result in poor emissions performance. Any of these can increase your operating costs.
We offer a huge range of OEM & Aftermarket Fuel Injectors for diggers, dumpers, excavators, telescopic handler & Backhoe loaders for all makes and models
All our Fuel Injectors come with 12-month warranty and free economy shipping to North America & Europe.
We ships via UPS Ground. Next day air shipping can be arranged for a reasonable price of anywhere from $50.00 - $100.00 depending on the weight of the product and your location. We will do everything we can to make sure that you get the service you need. We understand how important it is to receive your order as quickly as possible.
In most cases we only need one address, as long as your product is shipping to the same location as your billing information. In order to eliminate credit card fraud, your billing information must match the credit card you provide.
CATERPILLAR C6.6 HIGH PRESSURE FUEL PUMP 2005: OEM 2641A405— $3,850.00
(PART NUMBER : 352-6584RM, WEIGHT : 36.00 LBS, ADDITIONAL OEM : 10R7659, 352-6584, 295-9125, 2641A403)
CATERPILLAR C7, 4.4L, 6.6L HIGH PRESSURE FUEL PUMP 2014-2018: OEM 375-2647— $1,150.00
(PART NUMBER : 3752647RM, WEIGHT : 35.00 LBS, ADDITIONAL OEM : 0445025601, 0445025602, T410930)
CATERPILLAR C7, C9 HIGH PRESSURE FUEL PUMP 2008-2010: OEM 10R6350— $4,150.00
(PART NUMBER : 10R6350RM, WEIGHT : 38.00 LBS, ADDITIONAL OEM : 379-3460)
CATERPILLAR C7.1, C6.6 HIGH PRESSURE FUEL PUMP 2010-2014: OEM 368-9041— $1,650.00
(PART NUMBER : 368-9041RM, WEIGHT : 12.00 LBS, ADDITIONAL OEM : 20R4782, 294050-0521, 294050-0520)
CATERPILLAR C9 HIGH PRESSURE FUEL PUMP 2011-2013: OEM 511-7975— $2,250.00
(PART NUMBER : 511-7975RM, WEIGHT : 35.00 LBS, ADDITIONAL OEM : 5117975, 379-0150, 3790150, 341-8700, 3418700, 375-5244, 375-5244, 494-9679, 4939679, 353-7102, 3537102, 3696680, 369-6680, 3755244, 493-9679)
CATERPILLAR CT11, CT13 HIGH PRESSURE FUEL PUMP 2011-2015: OEM 421-3135— $1,970.00
( PART NUMBER : 421-3135TX, WEIGHT : 42.00 LBS, ADDITIONAL OEM : 4213155)
CATERPILLAR C6.6 HIGH PRESSURE FUEL PUMP 2005-2022: OEM 2641A312 —-$3,950.00
( PART NUMBER : 351-0973RM, WEIGHT : 36.00 LBS, ADDITIONAL OEM : 10R7660, 2641A304, 2641A306, 351-0973, 315-3019, 317-8021, 10R7660)
CATERPILLAR C3, C4 FUEL PUMP : OEM 1411350001 / 3369190 — $1,970.00
( PART NUMBER : 1411350001RM, WEIGHT : 12.00 LBS, ADDITIONAL OEM : 1411350001 / 3369190 )
CATERPILLAR 3126 FUEL INJECTOR 1995-2004: OEM 10R0782 ( SET OF 6 ) --- $1,758.00
(PART NUMBER : 10R0782RM-SET, WEIGHT : 21.00 LBS, PRIMARY OEM : 10R0782)
ADDITIONAL NOTES: All parts are proudly remanufactured in the U.S.A. to the highest of OEM standards, and improvements are often applied to the original design in the remanufacturing process.
If you need help selecting a fuel injector or pump for your machine don't hesitate to get in touch. Our specialists will be happy to advise you to ensure you get the right part for your specific machine.
dieselparts@engineer.com
USA: 1 (240) 330 8999
