CA Hand Clutch Seal Question
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Topic: CA Hand Clutch Seal Question
    Posted: 12 Jun 2024 at 6:30pm
I'll be working on the hand clutch soon and I'm wondering if I should pre-order any seals.  Of course I'm hoping its all there and in good working order otherwise.  There are no apparent seal leaks that I can see in any of the inspection holes.  What about:
70206449 (2), 70230851 (2), 70232186?
(final drive/axel, final drive clutch sections)
1952 CA13092
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2024 at 9:59pm
If your tearing down a 70 year old tractor, i would definitely put new seals.. Probably be old and cracked even if they dont leak..
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2024 at 12:49pm
I ordered the seals.  I just hope and pray there's nothing else seriously wrong :(
Symptoms:  Weak spring force only from aft to mid handle position.  You can manually move the handle from there forward with only a little resistance.  Appears there is enough engagement to move the tractor but unsure yet about actually pulling something.
1952 CA13092
