D-17 High Crop Diesel
Mauldin1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mauldin1 Quote  Post ReplyReply Direct Link To This Post Topic: D-17 High Crop Diesel
    Posted: 09 Jun 2024 at 1:37pm
I own a D17, single front wheel, high crop with the 6 cylinder N/A diesel. How rare is this tractor? Have only found a few pictures online with the single wheel high crop and they only had gas engines.
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2024 at 9:47pm
Not sure how rare.  Dad took a picture of a D17 hi crop single front wheel propane near Beatrice NE several years ago!
Greg Kroeker
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2024 at 9:58pm
Welcome to the forum.
Would have to see more pictures. The front single wheel doesn’t look high crop. Hopefully some of the other gentlemen that have more knowledge on high crops will chime in
RedHeeler79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2024 at 10:17pm
According to Swinford’s book, only about 40 single front wheel diesels were made in 58-59, and no other numbers shown for the later years. The grille, oval muffler, lights on fenders, etc appear to be series 3 or newer. Maybe someone converted it to its present configuration. Who knows? Please provide the serial number for the tractor. Would definitely tell more of the story.
Edited by RedHeeler79 - 09 Jun 2024 at 10:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mauldin1 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2024 at 1:16am
This is the only picture I have right now. Will have to cut the briar patch down to get to the serial number. My daughter was wanting to start going to tractor shows and i thought this would be something different from the John Deere and Farmall crowds.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mauldin1 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2024 at 1:24am
We are the second owner of it. The original owner had it set up with the spray boom and all for cotton and corn. I thought the drop boxes on the rear axle housing is what considered it to be a high crop.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2024 at 4:42am
Similar D-17 Diesel High Crop posted on the Forum in 2012.
Was located in Phoenix, AZ
G
https://www.allischalmers.com/forum/d-17-single-front-wheel-high-crop-d_topic54839.html
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2024 at 7:26am
“... I thought the drop boxes on the rear axle housing is what considered it to be a high crop.”
All D17s had drop boxes on the rear axles.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2024 at 3:42pm
I don't think it's a factory high crop.  Looks like someone just put taller wheels on the back of a regular D17 and called it a high crop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2024 at 7:50pm
That’s what I was thinking dseries.
But no matter what it is I like your idea of daughter taking to tractor shows
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2024 at 9:37am
Looking at this photo, several things stand out..
The hydraulic leaver is on the steering column with light on fenders and oval muffler. Makes it a series III...
It could have originally been a high crop with longer final drop housings. As the fenders are located much higher from the tire than a standard row crop ......
The photo I have included is a standard row crop D17 IV tractor with 38" rear and a 16" front .
Edited by Macon Rounds - 11 Jun 2024 at 9:39am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2024 at 7:14pm
Macon brings up a good point with the fenders. Or is it an allusion and tires spaced out far away.
Edited by Mikez - 11 Jun 2024 at 7:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mauldin1 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2024 at 7:17pm
It's wide and tall
BILLP-SE-MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2024 at 8:33pm
here is my WD SFW High Crop
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2024 at 8:35pm
have a few other sfw's also
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2024 at 8:37pm
SFW WC
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2024 at 8:39pm
SFW RC
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2024 at 8:47pm
On your D17 it has the standard fork, hc forks were extended 3 inches. for the solid cast wheel 9-10 tire or the spoke type wheel 7.50 -16 tire.the rear wheels would be 38 in spin outs.
have a good one Bill P
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2024 at 9:06am
MikeZ
Brings up a good point...
I believe the the fenders only look like there higher in regard to the rear tires. Due to the wide wheel spacing and photo angle....
So it is a standard row crop tractor with 38" rear and SFW.
These tractors are referred to as high clearance tractors...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2024 at 9:10am
These three tractors are all configured as high clearance...
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2024 at 7:37pm
the d17 series 1 diesel parts tractor that i have has taller fender mountsabout 4 inches higher than my other d17d  it all looks the same except every thing is just taller
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2024 at 9:26pm
Nice looking tractors everyone. Neat to see some single front wheel tractors, don’t see those often. Bill that’s a nice collection that you have, did you do the restorations?
Rob
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2024 at 6:47pm
Rob.  If they needed  any repair I did the work, painted them also.
 for got to add my   WD45  sfw in work clothes.
