Fully Mounted Snap Coupler Disks
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Topic: Fully Mounted Snap Coupler Disks
    Posted: 09 Jun 2024 at 11:13am
I have a nice IH 470 disk. It's plenty heavy and decent for tillage, but I have been thinking that a lighter, fully mounted AC disk would be nice for fast, shallow passes behind a WD/WD-45. I'd probably like to run around in 3rd in my WD and flip up small weed seedlings. This would be on previously worked ground if I had to delay planting due to getting rained out for a week or two, for example.
Any reason to pick a 20 vs. 40 series disk (or any other fully mounted AC disk models I'm not aware of)? I'm thinking 8-10' width since I would only be going maybe 2-3" deep, but if I'd have to add a bunch of weights to keep the front end down, that might be a reason to go with a narrower disk.
I'd be interested to hear from anyone with experience with a similar setup.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2024 at 7:30pm
The #20 disc harrows are a somewhat lighter design and very similar to the model 200 trailer type disc harrows.
   The #40 disc harrow is a deeper tillage heavier type disc that the cutting angle of the gangs can be adjusted.
  For what you are describing as you intended usage, the #20 fits the bill.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2024 at 5:23am
wjohn, they are handy, have one for the CA's. I also have a 7' 200 pull-type, it was cut down by a previous owner. That thing is handy as a pocket on a shirt!
LaJaMe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaJaMe Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2024 at 6:37pm
My Dad had one when i was growing up.  Behind a 45.  Handled just fine and was fun for a young kid making the turns at each end of the field. Lift, slip the hand clutch, hit one brake while turning, front end comes up a little, drop and go.  M y brother still has one behind my 45
