I600 rotary swing cylinder seals
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: I600 rotary swing cylinder seals
    Posted: 05 Jun 2024 at 5:36am
I’ve found AGCO part number 837180M92 seal kit. Will this fit my Cessna swing cylinder on my I600?
$733.00
I want to make sure this is the correct parts.
I haven’t removed the rotary swing cylinder yet. Want to know parts are available first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2024 at 11:35pm
MF used that as did IH and a few other MFG .
The assembly of the unit is fairly straight forward , on mine I had drift and found a chip out of rotary vane that I welded up , but on assembly the top seal was hard to get into position and I now have weeping from that area on top of cylinder .
https://www.youtube.com/watch?v=85tKu12TARo
https://www.youtube.com/watch?v=rNIq4zCdMHo
Nov 20, 2015 — I have an HD4 with the Industrial 600 backhoe attachment on it, and my rotary swing cylinder recently developed a pretty bad leak. Back to ...
Edited by Coke-in-MN - 09 Jun 2024 at 11:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2024 at 11:52pm
https://forums.yesterdaystractors.com/threads/model-54-backhoe-rotary-swing-cylinder-conversion.1569439/
https://www.tractorbynet.com/forums/threads/wtb-cessna-rotary-cylinder-parts.368232/
Backhoe - WTB Cessna Rotary Cylinder parts
Aug 11, 2016 — I am rebuilding a 1959 Allis Chalmers D14 Industrial Backhoe/Loader and currently have the Cessna Rotary swing cylinder/Actuator tore apart ...
Missing: piston ‎| Show results with: piston
Edited by Coke-in-MN - 09 Jun 2024 at 11:57pm
